Old 10-10-2018, 04:40 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Creating Show ExternalID
I'm working on a plugin to integrate Trakt.tv with Sage. One of the things I'd like to do is if a user watches a show on some other device mark the same show as watched on Sage. In the case where that show already exists on Sage it's pretty easy. In the case where it does not exist on Sage I need to use AddShow() to add a new Show/Airing Object to the wiz.bin.
My question is how do I generate a Show ExternalID that will match any future airing of that show? (Or does show ID matter?)
For example, if a user watches Breaking Bad on Netflix I want to create a Show on Sage so that if any time in the future Breaking Bad is aired on TV the episodes marked watched on NetFlix will appear as watched on Sage.
Old 10-10-2018, 09:24 AM
Personally if the show can't be found in sagetv, then I'd skip it. There won't be a reliable way for you to do this manually (ie, create the AiringID that sagetv would eventually use for that airing). Plus, it'll potentially add lots of shows and airings to the Wiz.bin, that might never originate from a recording. (ie, if I sync my netflix status to Trakt and then to Sage, then sage will get lots of shows that it would never otherwise have known about.
Old 10-10-2018, 11:46 AM
tmiranda's Avatar
That makes my life simpler.
I thought you'd want this functionality. If you don't think it's necessary then I'll skip it.
Old 10-10-2018, 12:25 PM
Tiki's Avatar
Tiki Tiki is offline
Iím guessing this sync routine will be run periodically (maybe a few times per day)? In that case if the missing episode does show up in Sageís EPG data at some time in the future, the watched status should transfer over then (and Sage will know that it doesnít need to record it since you already watched it somewhere else).
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 10-10-2018, 01:08 PM
dstanley's Avatar
dstanley dstanley is offline
I'm thinking along the lines of Sean as well - I don't think it is a 'deal-breaker' to leave out the possible future recording of a Sage item.
I record so little anymore that tracking that portion should be fairly easy and either delete items or monitor upcoming recordings.
If the plug-in matures and the opportunity arises to include something like that, well, then that would be fine too.
Dwight
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.7.2/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB
Old 10-10-2018, 01:34 PM
tmiranda's Avatar
Right now the sync will run daily and will only collect data on shows that were watched since the last sync. I really do not want to have to process all the shows that were ever watched. Seems a waste of resources.
Old 10-10-2018, 01:36 PM
tmiranda's Avatar
Dwight
Maybe I can think about it in another way. I can monitor Sage recordings and when one completes I can check trakt to see if it's been watched elsewhere. I'll have to think it through a little more but at first glance this seems reasonable.
Old 10-10-2018, 08:15 PM
EnterNoEscape's Avatar
Why do you say that? SageTV does something like this all the time when you add favorites or finish an EPG sync. I wouldn't think it would be a problem to check once after any EPG update or maybe we could add a way to subscribe to an event generated any time a new Show is added to Wiz.bin.
The only problem here is that we just recorded a show that we didn't need to and possibly prevented another show from recording. Maybe a compromise would be to get the schedule for the next 24 hours (this has some gotchas too) and use that to reduce the scope, but still mark things watched before they potentially move recordings or cause them to not happen all together.
In a similar thought process, is there any value in marking it watched the instant it starts recording? Will that cause it to stop recording and free up the tuner?
Old 10-10-2018, 08:49 PM
wnjj wnjj is online now
Can you use 'GetFavoriteAirings' along with 'GetAiringStartTime' to see if any 'already watched' favorites are scheduled in the future and then mark those as watched?
Old 10-10-2018, 09:00 PM
I believe that would work. If you use intelligent recordings, this approach would miss those, but I guess that's not a big deal since they can't cause you to miss a recording you wanted.
Old 10-11-2018, 03:50 AM
tmiranda's Avatar
I think there is a GetAiringsThatWillBeRecorded API that may be better suited.
Old 10-11-2018, 08:24 AM
I hadnít looked in Global. Thereís a GetScheduledRecordings.
Old 10-11-2018, 11:12 AM
tmiranda's Avatar
Yes, that's what I was thinking of.
How do I edit externalid? JohnLG Batch Metadata Tools 3 03-14-2012 05:49 AM
ExternalID and Series & Episode Numbers Black Sky Batch Metadata Tools 3 01-12-2011 02:23 PM
Help Creating A Theme robhix SageMC Custom Interface 0 01-16-2009 08:49 PM
creating STVi matrix35 SageTV Studio 6 02-25-2007 06:48 PM
Help creating h.264 mp4 with SageTVTranscoder Wade SageTV Beta Test Software 5 11-19-2006 06:17 PM
