Old 06-14-2008, 02:38 PM
gveres gveres is offline
Looking for a way to export recording info as SageXML
Is there a way to export a SageXML file from the webserver? Or any other plugin?
I really want to import, but there is just a ton of information that you can't get easily - like favourite id. I would like to export an xml file from one of the existing recordings and then use it as a template to import the show that Sage "forgot" it recorded.
Any pointers?
Greg
Old 06-14-2008, 07:44 PM
http://forums.sagetv.com/forums/show...=xml+generator
Old 06-14-2008, 08:29 PM
Any pointers?
Greg
Use the webserver click on a recording then just simply click the XML file button and you are done. That is already availible in the WebServer.
Old 06-14-2008, 08:30 PM
Yea that isn't what I was looking for. I want to create the xml selectively for one or two shows.
It turns out the webserver does this. On each page that contains info about a show or from the guide description of a show, you can click on the XML icon that is beside the screen title and it will generate the XML file. I stumbled on it quite by accident.
Greg
SageTV V6.3 is now available for Win/Linux! Narflex Announcements 1 03-07-2008 12:33 PM
SageTV V6.3.2 Beta is Available! Narflex SageTV Beta Test Software 0 11-21-2007 07:08 PM
HD Homerun Recording High CPU Usage smarty Hardware Support 6 10-18-2007 05:31 AM
Recording artefacts upon editing. Freerider4 SageTV Software 0 02-01-2006 09:13 PM
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) Cayars SageTV Customizations 3664 12-13-2005 05:35 PM
