Old 03-12-2016, 08:14 PM
need help installing linux drivers
hi,
I am taking the plunge to switch from win 7 to linux sagetv install. I have hauppauge 2250 & 2255 cards. I am looking at this link for the drivers http://www.hauppauge.com/site/support/linux.html It lists the drivers as ubuntu 14.04.03 I am using a different linux distro linuxmint debian to be exact. Will these drivers work with my os? i know ubuntu is based on debian so hoping that any custom ubuntu tweaks wont impare the drivers from working. or is there a better option for needed linux drivers?
galaxysurfer
Old 03-12-2016, 09:55 PM
http://www.webclaw.info/2016/02/buil...intv-hvr-2255/
found this link that may help others out there with same card
Old 03-13-2016, 06:18 AM
Before rebuilding a kernel, etc, I'd just try the card in your distro and see if it is picked up or not. In many cases, if you are running a newer version of linux, the drivers might already be there.
Old 03-20-2016, 01:32 AM
I am using Hauppauge 1 of 2250 & 2 of 2255 cards. I was told that 2255 drivers are included in 4.2 kernel. my distro is running an older kernel 3.19 . I am afraid to update in case i break something. The older 2250 card is not incl but was given a link to linuxtv.org http://www.linuxtv.org/wiki/index.ph...WinTV-HVR-2250 never been good with drivers. i have always been lucky with linux distro working right out of the box so to speak.
Old 03-20-2016, 07:14 AM
My recommendation is to upgrade. I had to go through this when the HDPVR was first released, and everytime I'd take a new kernel update, then I'd have to rebuild the drivers. Many things will "just work" in Linux, but if you staying on a very old kernel, that is not going to be the case
What are you running that you need to stay on an old kernel?
Installing Drivers for HD-PVR on WHS HELP! dibs Hardware Support 8 06-04-2008 10:17 AM
Problem installing Hauppauge 250MCE drivers. nyle Hardware Support 1 05-20-2007 06:59 AM
Installing drivers causes reboot. BlueRidgeMark Hardware Support 0 12-31-2006 06:19 PM
Installing Drivers for PVR-350 and 150 Pegleg Hardware Support 1 10-19-2005 10:26 AM
PVR350 Errors out when installing drivers on new Dell Dimension 2400 tundrwd Hardware Support 5 01-23-2004 08:25 AM
