Old 02-22-2017, 04:27 AM
V9 in 2 directories!
After installing V9, I discovered that I've accidentally installed it in a different directory from my original installation. It was originally on the root directory, now V9 is in c:/program files (x86)/SageTV and has paths in its' configuration that point to c:\SageTV. Is there a way to get the whole system into c:/program files (x86)/?
ASRock B450M Pro4 AM4 mATX AMD Motherboard, AMD Ryzen 5 2600 3.4GHz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD - Black SN750 NVMe SSD 250GB, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-dualHD USB, Windows 10 64bit
Old 02-22-2017, 06:55 PM
One way would be to uninstall SageTV and delete the "...(x86)/SageTV" directory and then reinstall the application choosing where it is installed this time. You might wait to see if someone else has better advise for you but that should work. Now if you want to keep the "...(x86)/SageTV" directory then definitely wait for better advice.
Old 02-22-2017, 11:14 PM
i was able to patch it up with some file copying and a big edit to sage.properties.
Import Directories SFlex SageTV Media Extender 8 04-18-2010 04:09 PM
Can't delete DVD directories phunny SageTV Beta Test Software 2 06-21-2009 06:09 AM
Import directories viperdiablo SageTV Software 0 12-13-2008 06:13 PM
Import Directories rickgillyon SageTV Beta Test Software 1 10-11-2006 03:15 AM
Import Directories Francois Parent SageTV Software 1 02-26-2006 07:52 AM
