Old 02-18-2018, 09:38 PM
Dahrl Dahrl is offline
Exclamation Network encoder tuning problem with HDPVR
Having a issue here with adding a network encoder.
I have multiple HDPVR's and been planning to move them all to network encoders. I setup a first box and it works fine for tuning channels and recording in general.
When the network encoder is added to the main server.
I have A local HDPVR and B network encoder HDPVR. Both using internal IR blaster. The network encoder is set to NOT do any tuning on the main itself, so that the network encoder will do its own tuning.
The problem is this, A local HDPVR tunes fine always, but as a network encoder B tunes A and B which messed up anything on A.
Both tuners when tested directly only tune themselves to the correct channel from their direct Sagetv. So there is no IR bleed happening. And it only happens for one and not the other.
I believe this is a bug somewhere that any local IR Blasters are being tuned with a network enocder using the same remote type.
Any thoughts?
Old 02-20-2018, 12:11 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Check to see if the 'tuning_plugin' property for the network encoder configuration in the mmc/encoders on the main server has a value...if it does then remove it and that would fix the problem I think.
Jeffrey Kardatzke
Google
Founder of SageTV
Narflex's Avatar
Sage
If that doesn't work, then post the Sage.properties file from your main server and your network encoder.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-21-2018, 09:30 AM
Smile
I was not able to make sense of my mmc section
I had thought it was mmc/encoders/######/property=value
where the leading negative numbers are old disabled / hidden encoders that are no longer plugged in.
At the time of this config (sage.properties) I had two encoders setup, one is local, one is network, but both using internal HDPVR ir blaster.
mmc/always_tune_channel=true
mmc/country=Canada
mmc/country_code=1
mmc/dshow_cap_dev_categories={65E8773D-8F56-11D0-A3B9-00A0C9223196},{FD0A5AF4-B41D-11d2-9C95-00C04F7971E0},{71985F48-1CA1-11d3-9CC8-00C04F7971E0}
mmc/enable_merit_editing=false
mmc/enable_mpeg4_timeshifting=true
mmc/encoders/-1674637829/2/0/available_channels=
mmc/encoders/-1674637829/2/0/brightness=-1
mmc/encoders/-1674637829/2/0/broadcast_standard=
mmc/encoders/-1674637829/2/0/contrast=-1
mmc/encoders/-1674637829/2/0/device_name=
mmc/encoders/-1674637829/2/0/hue=-1
mmc/encoders/-1674637829/2/0/last_channel=
mmc/encoders/-1674637829/2/0/provider_id=0
mmc/encoders/-1674637829/2/0/saturation=-1
mmc/encoders/-1674637829/2/0/sharpness=-1
mmc/encoders/-1674637829/2/0/tuning_mode=
mmc/encoders/-1674637829/2/0/tuning_plugin=
mmc/encoders/-1674637829/2/0/tuning_plugin_port=0
mmc/encoders/-1674637829/2/0/video_crossbar_index=0
mmc/encoders/-1674637829/2/0/video_crossbar_type=2
mmc/encoders/-1674637829/3/0/available_channels=
mmc/encoders/-1674637829/3/0/brightness=128
mmc/encoders/-1674637829/3/0/broadcast_standard=
mmc/encoders/-1674637829/3/0/contrast=64
mmc/encoders/-1674637829/3/0/device_name=
mmc/encoders/-1674637829/3/0/hue=125
mmc/encoders/-1674637829/3/0/last_channel=
mmc/encoders/-1674637829/3/0/provider_id=0
mmc/encoders/-1674637829/3/0/saturation=64
mmc/encoders/-1674637829/3/0/sharpness=128
mmc/encoders/-1674637829/3/0/tuning_mode=
mmc/encoders/-1674637829/3/0/tuning_plugin=
mmc/encoders/-1674637829/3/0/tuning_plugin_port=0
mmc/encoders/-1674637829/3/0/video_crossbar_index=0
mmc/encoders/-1674637829/3/0/video_crossbar_type=3
mmc/encoders/-1674637829/5/0/available_channels=
mmc/encoders/-1674637829/5/0/brightness=-1
mmc/encoders/-1674637829/5/0/broadcast_standard=
mmc/encoders/-1674637829/5/0/contrast=-1
mmc/encoders/-1674637829/5/0/device_name=
mmc/encoders/-1674637829/5/0/hue=-1
mmc/encoders/-1674637829/5/0/last_channel=
mmc/encoders/-1674637829/5/0/provider_id=0
mmc/encoders/-1674637829/5/0/saturation=-1
mmc/encoders/-1674637829/5/0/sharpness=-1
mmc/encoders/-1674637829/5/0/tuning_mode=
mmc/encoders/-1674637829/5/0/tuning_plugin=
mmc/encoders/-1674637829/5/0/tuning_plugin_port=0
mmc/encoders/-1674637829/5/0/video_crossbar_index=0
mmc/encoders/-1674637829/5/0/video_crossbar_type=5
mmc/encoders/-1674637829/90/0/available_channels=
mmc/encoders/-1674637829/90/0/brightness=128
mmc/encoders/-1674637829/90/0/broadcast_standard=
mmc/encoders/-1674637829/90/0/contrast=64
mmc/encoders/-1674637829/90/0/device_name=Explorer4250HD-z1
mmc/encoders/-1674637829/90/0/hue=125
mmc/encoders/-1674637829/90/0/last_channel=348
mmc/encoders/-1674637829/90/0/provider_id=8593809
mmc/encoders/-1674637829/90/0/saturation=64
mmc/encoders/-1674637829/90/0/sharpness=128
mmc/encoders/-1674637829/90/0/tuning_mode=
mmc/encoders/-1674637829/90/0/tuning_plugin=C\:\\Program Files (x86)\\SageTV\\Common\\uu_irsage.dll
mmc/encoders/-1674637829/90/0/tuning_plugin_port=0
mmc/encoders/-1674637829/90/0/video_crossbar_index=0
mmc/encoders/-1674637829/90/0/video_crossbar_type=90
mmc/encoders/-1674637829/audio_capture_device_index=-1
mmc/encoders/-1674637829/audio_capture_device_name=
mmc/encoders/-1674637829/audio_capture_device_num=0
mmc/encoders/-1674637829/audio_processor=
mmc/encoders/-1674637829/broadcast_standard=
mmc/encoders/-1674637829/capture_config=1050624
mmc/encoders/-1674637829/default_device_quality=
mmc/encoders/-1674637829/delay_to_wait_after_tuning=4444
mmc/encoders/-1674637829/device_class=DirectShow
mmc/encoders/-1674637829/dshow_tv_type=
mmc/encoders/-1674637829/encoder_merit=0
mmc/encoders/-1674637829/encoding_host=
mmc/encoders/-1674637829/forced_video_storage_path_prefix=
mmc/encoders/-1674637829/last_cross_index=0
mmc/encoders/-1674637829/last_cross_type=90
mmc/encoders/-1674637829/live_audio_input=
mmc/encoders/-1674637829/never_stop_encoding=false
mmc/encoders/-1674637829/video_capture_device_name=Hauppauge HD PVR Capture Device
mmc/encoders/-1674637829/video_capture_device_num=3
mmc/encoders/-1674637829/video_encoding_params=Good-H.264
mmc/encoders/-1674637829/video_processor=
mmc/encoders/-1674637830/2/0/available_channels=
mmc/encoders/-1674637830/2/0/brightness=-1
mmc/encoders/-1674637830/2/0/broadcast_standard=
mmc/encoders/-1674637830/2/0/contrast=-1
mmc/encoders/-1674637830/2/0/device_name=
mmc/encoders/-1674637830/2/0/hue=-1
mmc/encoders/-1674637830/2/0/last_channel=
mmc/encoders/-1674637830/2/0/provider_id=0
mmc/encoders/-1674637830/2/0/saturation=-1
mmc/encoders/-1674637830/2/0/sharpness=-1
mmc/encoders/-1674637830/2/0/tuning_mode=
mmc/encoders/-1674637830/2/0/tuning_plugin=
mmc/encoders/-1674637830/2/0/tuning_plugin_port=0
mmc/encoders/-1674637830/2/0/video_crossbar_index=0
mmc/encoders/-1674637830/2/0/video_crossbar_type=2
mmc/encoders/-1674637830/3/0/available_channels=
mmc/encoders/-1674637830/3/0/brightness=128
mmc/encoders/-1674637830/3/0/broadcast_standard=
mmc/encoders/-1674637830/3/0/contrast=64
mmc/encoders/-1674637830/3/0/device_name=
mmc/encoders/-1674637830/3/0/hue=125
mmc/encoders/-1674637830/3/0/last_channel=
mmc/encoders/-1674637830/3/0/provider_id=0
mmc/encoders/-1674637830/3/0/saturation=64
mmc/encoders/-1674637830/3/0/sharpness=128
mmc/encoders/-1674637830/3/0/tuning_mode=
mmc/encoders/-1674637830/3/0/tuning_plugin=
mmc/encoders/-1674637830/3/0/tuning_plugin_port=0
mmc/encoders/-1674637830/3/0/video_crossbar_index=0
mmc/encoders/-1674637830/3/0/video_crossbar_type=3
mmc/encoders/-1674637830/5/0/available_channels=
mmc/encoders/-1674637830/5/0/brightness=-1
mmc/encoders/-1674637830/5/0/broadcast_standard=
mmc/encoders/-1674637830/5/0/contrast=-1
mmc/encoders/-1674637830/5/0/device_name=
mmc/encoders/-1674637830/5/0/hue=-1
mmc/encoders/-1674637830/5/0/last_channel=
mmc/encoders/-1674637830/5/0/provider_id=0
mmc/encoders/-1674637830/5/0/saturation=-1
mmc/encoders/-1674637830/5/0/sharpness=-1
mmc/encoders/-1674637830/5/0/tuning_mode=
mmc/encoders/-1674637830/5/0/tuning_plugin=
mmc/encoders/-1674637830/5/0/tuning_plugin_port=0
mmc/encoders/-1674637830/5/0/video_crossbar_index=0
mmc/encoders/-1674637830/5/0/video_crossbar_type=5
mmc/encoders/-1674637830/90/0/available_channels=
mmc/encoders/-1674637830/90/0/brightness=128
mmc/encoders/-1674637830/90/0/broadcast_standard=
mmc/encoders/-1674637830/90/0/contrast=64
mmc/encoders/-1674637830/90/0/device_name=Explorer4250HD-z1
mmc/encoders/-1674637830/90/0/hue=125
mmc/encoders/-1674637830/90/0/last_channel=313
mmc/encoders/-1674637830/90/0/provider_id=8593809
mmc/encoders/-1674637830/90/0/saturation=64
mmc/encoders/-1674637830/90/0/sharpness=128
mmc/encoders/-1674637830/90/0/tuning_mode=
mmc/encoders/-1674637830/90/0/tuning_plugin=C\:\\Program Files (x86)\\SageTV\\Common\\uu_irsage.dll
mmc/encoders/-1674637830/90/0/tuning_plugin_port=0
mmc/encoders/-1674637830/90/0/video_crossbar_index=0
mmc/encoders/-1674637830/90/0/video_crossbar_type=90
mmc/encoders/-1674637830/audio_capture_device_index=-1
mmc/encoders/-1674637830/audio_capture_device_name=
mmc/encoders/-1674637830/audio_capture_device_num=0
mmc/encoders/-1674637830/audio_processor=
mmc/encoders/-1674637830/broadcast_standard=
mmc/encoders/-1674637830/capture_config=1050624
mmc/encoders/-1674637830/default_device_quality=
mmc/encoders/-1674637830/delay_to_wait_after_tuning=4444
mmc/encoders/-1674637830/device_class=DirectShow
mmc/encoders/-1674637830/dshow_tv_type=
mmc/encoders/-1674637830/encoder_merit=0
mmc/encoders/-1674637830/encoding_host=
mmc/encoders/-1674637830/forced_video_storage_path_prefix=
mmc/encoders/-1674637830/last_cross_index=0
mmc/encoders/-1674637830/last_cross_type=90
mmc/encoders/-1674637830/live_audio_input=
mmc/encoders/-1674637830/never_stop_encoding=false
mmc/encoders/-1674637830/video_capture_device_name=Hauppauge HD PVR Capture Device
mmc/encoders/-1674637830/video_capture_device_num=2
mmc/encoders/-1674637830/video_encoding_params=Good-H.264
mmc/encoders/-1674637830/video_processor=
mmc/encoders/-1674637831/2/0/available_channels=
mmc/encoders/-1674637831/2/0/brightness=-1
mmc/encoders/-1674637831/2/0/broadcast_standard=
mmc/encoders/-1674637831/2/0/contrast=-1
mmc/encoders/-1674637831/2/0/device_name=
mmc/encoders/-1674637831/2/0/hue=-1
mmc/encoders/-1674637831/2/0/last_channel=
mmc/encoders/-1674637831/2/0/provider_id=0
mmc/encoders/-1674637831/2/0/saturation=-1
mmc/encoders/-1674637831/2/0/sharpness=-1
mmc/encoders/-1674637831/2/0/tuning_mode=
mmc/encoders/-1674637831/2/0/tuning_plugin=
mmc/encoders/-1674637831/2/0/tuning_plugin_port=0
mmc/encoders/-1674637831/2/0/video_crossbar_index=0
mmc/encoders/-1674637831/2/0/video_crossbar_type=2
mmc/encoders/-1674637831/3/0/available_channels=
mmc/encoders/-1674637831/3/0/brightness=128
mmc/encoders/-1674637831/3/0/broadcast_standard=
mmc/encoders/-1674637831/3/0/contrast=64
mmc/encoders/-1674637831/3/0/device_name=
mmc/encoders/-1674637831/3/0/hue=125
mmc/encoders/-1674637831/3/0/last_channel=
mmc/encoders/-1674637831/3/0/provider_id=0
mmc/encoders/-1674637831/3/0/saturation=64
mmc/encoders/-1674637831/3/0/sharpness=128
mmc/encoders/-1674637831/3/0/tuning_mode=
mmc/encoders/-1674637831/3/0/tuning_plugin=
mmc/encoders/-1674637831/3/0/tuning_plugin_port=0
mmc/encoders/-1674637831/3/0/video_crossbar_index=0
mmc/encoders/-1674637831/3/0/video_crossbar_type=3
mmc/encoders/-1674637831/5/0/available_channels=
mmc/encoders/-1674637831/5/0/brightness=-1
mmc/encoders/-1674637831/5/0/broadcast_standard=
mmc/encoders/-1674637831/5/0/contrast=-1
mmc/encoders/-1674637831/5/0/device_name=
mmc/encoders/-1674637831/5/0/hue=-1
mmc/encoders/-1674637831/5/0/last_channel=
mmc/encoders/-1674637831/5/0/provider_id=0
mmc/encoders/-1674637831/5/0/saturation=-1
mmc/encoders/-1674637831/5/0/sharpness=-1
mmc/encoders/-1674637831/5/0/tuning_mode=
mmc/encoders/-1674637831/5/0/tuning_plugin=
mmc/encoders/-1674637831/5/0/tuning_plugin_port=0
mmc/encoders/-1674637831/5/0/video_crossbar_index=0
mmc/encoders/-1674637831/5/0/video_crossbar_type=5
mmc/encoders/-1674637831/90/0/available_channels=
mmc/encoders/-1674637831/90/0/brightness=128
mmc/encoders/-1674637831/90/0/broadcast_standard=
mmc/encoders/-1674637831/90/0/contrast=64
mmc/encoders/-1674637831/90/0/device_name=Explorer4250HD-z2
mmc/encoders/-1674637831/90/0/hue=125
mmc/encoders/-1674637831/90/0/last_channel=178
mmc/encoders/-1674637831/90/0/provider_id=8593809
mmc/encoders/-1674637831/90/0/saturation=64
mmc/encoders/-1674637831/90/0/sharpness=128
mmc/encoders/-1674637831/90/0/tuning_mode=
mmc/encoders/-1674637831/90/0/tuning_plugin=C\:\\Program Files (x86)\\SageTV\\Common\\uu_irsage.dll
mmc/encoders/-1674637831/90/0/tuning_plugin_port=0
mmc/encoders/-1674637831/90/0/video_crossbar_index=0
mmc/encoders/-1674637831/90/0/video_crossbar_type=90
mmc/encoders/-1674637831/audio_capture_device_index=-1
mmc/encoders/-1674637831/audio_capture_device_name=
mmc/encoders/-1674637831/audio_capture_device_num=0
mmc/encoders/-1674637831/audio_processor=
mmc/encoders/-1674637831/broadcast_standard=
mmc/encoders/-1674637831/capture_config=1050624
mmc/encoders/-1674637831/default_device_quality=
mmc/encoders/-1674637831/delay_to_wait_after_tuning=4444
mmc/encoders/-1674637831/device_class=DirectShow
mmc/encoders/-1674637831/dshow_tv_type=
mmc/encoders/-1674637831/encoder_merit=0
mmc/encoders/-1674637831/encoding_host=
mmc/encoders/-1674637831/forced_video_storage_path_prefix=
mmc/encoders/-1674637831/last_cross_index=0
mmc/encoders/-1674637831/last_cross_type=90
mmc/encoders/-1674637831/live_audio_input=
mmc/encoders/-1674637831/minimum_bitrate_error_threshold_bps=0
mmc/encoders/-1674637831/never_stop_encoding=false
mmc/encoders/-1674637831/video_capture_device_name=Hauppauge HD PVR Capture Device
mmc/encoders/-1674637831/video_capture_device_num=1
mmc/encoders/-1674637831/video_encoding_params=Good-H.264
mmc/encoders/-1674637831/video_processor=
mmc/encoders/-431556906/2/0/available_channels=
mmc/encoders/-431556906/2/0/brightness=-1
mmc/encoders/-431556906/2/0/broadcast_standard=
mmc/encoders/-431556906/2/0/contrast=-1
mmc/encoders/-431556906/2/0/device_name=
mmc/encoders/-431556906/2/0/hue=-1
mmc/encoders/-431556906/2/0/last_channel=
mmc/encoders/-431556906/2/0/provider_id=0
mmc/encoders/-431556906/2/0/saturation=-1
mmc/encoders/-431556906/2/0/sharpness=-1
mmc/encoders/-431556906/2/0/tuning_mode=
mmc/encoders/-431556906/2/0/tuning_plugin=
mmc/encoders/-431556906/2/0/tuning_plugin_port=0
mmc/encoders/-431556906/2/0/video_crossbar_index=0
mmc/encoders/-431556906/2/0/video_crossbar_type=2
mmc/encoders/-431556906/3/0/available_channels=
mmc/encoders/-431556906/3/0/brightness=-1
mmc/encoders/-431556906/3/0/broadcast_standard=
mmc/encoders/-431556906/3/0/contrast=-1
mmc/encoders/-431556906/3/0/device_name=
mmc/encoders/-431556906/3/0/hue=-1
mmc/encoders/-431556906/3/0/last_channel=
mmc/encoders/-431556906/3/0/provider_id=0
mmc/encoders/-431556906/3/0/saturation=-1
mmc/encoders/-431556906/3/0/sharpness=-1
mmc/encoders/-431556906/3/0/tuning_mode=
mmc/encoders/-431556906/3/0/tuning_plugin=
mmc/encoders/-431556906/3/0/tuning_plugin_port=0
mmc/encoders/-431556906/3/0/video_crossbar_index=0
mmc/encoders/-431556906/3/0/video_crossbar_type=3
mmc/encoders/-431556906/5/0/available_channels=
mmc/encoders/-431556906/5/0/brightness=128
mmc/encoders/-431556906/5/0/broadcast_standard=
mmc/encoders/-431556906/5/0/contrast=64
mmc/encoders/-431556906/5/0/device_name=
mmc/encoders/-431556906/5/0/hue=125
mmc/encoders/-431556906/5/0/last_channel=
mmc/encoders/-431556906/5/0/provider_id=0
mmc/encoders/-431556906/5/0/saturation=64
mmc/encoders/-431556906/5/0/sharpness=128
mmc/encoders/-431556906/5/0/tuning_mode=
mmc/encoders/-431556906/5/0/tuning_plugin=
mmc/encoders/-431556906/5/0/tuning_plugin_port=0
mmc/encoders/-431556906/5/0/video_crossbar_index=0
mmc/encoders/-431556906/5/0/video_crossbar_type=5
mmc/encoders/-431556906/90/0/available_channels=
mmc/encoders/-431556906/90/0/brightness=128
mmc/encoders/-431556906/90/0/broadcast_standard=
mmc/encoders/-431556906/90/0/contrast=64
mmc/encoders/-431556906/90/0/device_name=StubDevice
mmc/encoders/-431556906/90/0/hue=125
mmc/encoders/-431556906/90/0/last_channel=36
mmc/encoders/-431556906/90/0/provider_id=4680422863964904703
mmc/encoders/-431556906/90/0/saturation=64
mmc/encoders/-431556906/90/0/sharpness=128
mmc/encoders/-431556906/90/0/tuning_mode=
mmc/encoders/-431556906/90/0/tuning_plugin=C\:\\Program Files (x86)\\SageTV\\Common\\HCWIRBlaster.dll
mmc/encoders/-431556906/90/0/tuning_plugin_port=0
mmc/encoders/-431556906/90/0/video_crossbar_index=0
mmc/encoders/-431556906/90/0/video_crossbar_type=90
mmc/encoders/-431556906/audio_capture_device_index=-1
mmc/encoders/-431556906/audio_capture_device_name=
mmc/encoders/-431556906/audio_capture_device_num=0
mmc/encoders/-431556906/audio_processor=
mmc/encoders/-431556906/broadcast_standard=
mmc/encoders/-431556906/capture_config=1050624
mmc/encoders/-431556906/default_device_quality=Great-H.264
mmc/encoders/-431556906/delay_to_wait_after_tuning=4444
mmc/encoders/-431556906/device_class=DirectShow
mmc/encoders/-431556906/dshow_tv_type=
mmc/encoders/-431556906/encoder_merit=0
mmc/encoders/-431556906/encoding_host=
mmc/encoders/-431556906/forced_video_storage_path_prefix=
mmc/encoders/-431556906/last_cross_index=0
mmc/encoders/-431556906/last_cross_type=90
mmc/encoders/-431556906/live_audio_input=
mmc/encoders/-431556906/minimum_bitrate_error_threshold_bps=0
mmc/encoders/-431556906/never_stop_encoding=false
mmc/encoders/-431556906/video_capture_device_name=Hauppauge HD PVR Capture Device
mmc/encoders/-431556906/video_capture_device_num=0
mmc/encoders/-431556906/video_encoding_params=Great-H.264
mmc/encoders/-431556906/video_processor=
mmc/encoders/1874746103/2/0/available_channels=
mmc/encoders/1874746103/2/0/brightness=-1
mmc/encoders/1874746103/2/0/broadcast_standard=
mmc/encoders/1874746103/2/0/contrast=-1
mmc/encoders/1874746103/2/0/device_name=
mmc/encoders/1874746103/2/0/hue=-1
mmc/encoders/1874746103/2/0/last_channel=
mmc/encoders/1874746103/2/0/provider_id=0
mmc/encoders/1874746103/2/0/saturation=-1
mmc/encoders/1874746103/2/0/sharpness=-1
mmc/encoders/1874746103/2/0/tuning_mode=
mmc/encoders/1874746103/2/0/tuning_plugin=
mmc/encoders/1874746103/2/0/tuning_plugin_port=0
mmc/encoders/1874746103/2/0/video_crossbar_index=0
mmc/encoders/1874746103/2/0/video_crossbar_type=2
mmc/encoders/1874746103/3/0/available_channels=
mmc/encoders/1874746103/3/0/brightness=-1
mmc/encoders/1874746103/3/0/broadcast_standard=
mmc/encoders/1874746103/3/0/contrast=-1
mmc/encoders/1874746103/3/0/device_name=
mmc/encoders/1874746103/3/0/hue=-1
mmc/encoders/1874746103/3/0/last_channel=
mmc/encoders/1874746103/3/0/provider_id=0
mmc/encoders/1874746103/3/0/saturation=-1
mmc/encoders/1874746103/3/0/sharpness=-1
mmc/encoders/1874746103/3/0/tuning_mode=
mmc/encoders/1874746103/3/0/tuning_plugin=
mmc/encoders/1874746103/3/0/tuning_plugin_port=0
mmc/encoders/1874746103/3/0/video_crossbar_index=0
mmc/encoders/1874746103/3/0/video_crossbar_type=3
mmc/encoders/1874746103/5/0/available_channels=
mmc/encoders/1874746103/5/0/brightness=128
mmc/encoders/1874746103/5/0/broadcast_standard=
mmc/encoders/1874746103/5/0/contrast=64
mmc/encoders/1874746103/5/0/device_name=
mmc/encoders/1874746103/5/0/hue=125
mmc/encoders/1874746103/5/0/last_channel=
mmc/encoders/1874746103/5/0/provider_id=0
mmc/encoders/1874746103/5/0/saturation=64
mmc/encoders/1874746103/5/0/sharpness=128
mmc/encoders/1874746103/5/0/tuning_mode=
mmc/encoders/1874746103/5/0/tuning_plugin=
mmc/encoders/1874746103/5/0/tuning_plugin_port=0
mmc/encoders/1874746103/5/0/video_crossbar_index=0
mmc/encoders/1874746103/5/0/video_crossbar_type=5
mmc/encoders/1874746103/90/0/available_channels=
mmc/encoders/1874746103/90/0/brightness=128
mmc/encoders/1874746103/90/0/broadcast_standard=
mmc/encoders/1874746103/90/0/contrast=64
mmc/encoders/1874746103/90/0/device_name=StubDevice
mmc/encoders/1874746103/90/0/hue=125
mmc/encoders/1874746103/90/0/last_channel=11
mmc/encoders/1874746103/90/0/provider_id=4680422863964904703
mmc/encoders/1874746103/90/0/saturation=64
mmc/encoders/1874746103/90/0/sharpness=128
mmc/encoders/1874746103/90/0/tuning_mode=
mmc/encoders/1874746103/90/0/tuning_plugin=C\:\\Program Files (x86)\\SageTV\\Common\\HCWIRBlaster.dll
mmc/encoders/1874746103/90/0/tuning_plugin_port=0
mmc/encoders/1874746103/90/0/video_crossbar_index=0
mmc/encoders/1874746103/90/0/video_crossbar_type=90
mmc/encoders/1874746103/audio_capture_device_index=-1
mmc/encoders/1874746103/audio_capture_device_name=
mmc/encoders/1874746103/audio_capture_device_num=0
mmc/encoders/1874746103/audio_processor=
mmc/encoders/1874746103/broadcast_standard=
mmc/encoders/1874746103/capture_config=1050624
mmc/encoders/1874746103/default_device_quality=Great-H.264
mmc/encoders/1874746103/delay_to_wait_after_tuning=4444
mmc/encoders/1874746103/device_class=
mmc/encoders/1874746103/dshow_tv_type=
mmc/encoders/1874746103/encoder_merit=0
mmc/encoders/1874746103/encoding_host=sagetv-rec1\:6969
mmc/encoders/1874746103/fast_network_encoder_switch=false
mmc/encoders/1874746103/forced_video_storage_path_prefix=
mmc/encoders/1874746103/last_cross_index=0
mmc/encoders/1874746103/last_cross_type=90
mmc/encoders/1874746103/live_audio_input=
mmc/encoders/1874746103/minimum_bitrate_error_threshold_bps=0
mmc/encoders/1874746103/multicast_host=
mmc/encoders/1874746103/never_stop_encoding=false
mmc/encoders/1874746103/video_capture_device_name=Hauppauge HD PVR Capture Device
mmc/encoders/1874746103/video_capture_device_num=0
mmc/encoders/1874746103/video_encoding_params=Good-H.264
mmc/encoders/1874746103/video_processor=
mmc/fake_functioning_tuners=false
mmc/feature_mask_disable=0
mmc/hdpvr_magic=true
mmc/hdpvr_magic2=false
mmc/ignore_encoders=NVIDIA DualTV YUV Capture|Sound Blaster X-Fi Xtreme Audio|NVIDIA DualTV YUV Capture 2|Realtek HD Audio Stereo input|
mmc/ir_xmt_port=0
mmc/last_encoder_name=Hauppauge HD PVR Capture Device
mmc/net_encoding_connection_timeout=2000
mmc/net_encoding_timeout=15000
mmc/pentium_4_fix=false
mmc/remove_non_numeric_characters_from_channel_change_strings=false
mmc/retain_lineups_for_lost_devices=true
mmc/set_crossbar_redundantly=false
mmc/sfir_dev_name=
mmc/video_format_code=1
Old 02-21-2018, 06:05 PM
Narflex's Avatar
Sage
Delete this line from the properties file and it should fix the problem:
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-22-2018, 07:02 AM
That did it, I think that the "select no tuning device" should clear this value when selected. Because it retained it from a prior attempt to configure it as a network encoder. Or set a new property that says no tuning on the main server and simply ignore any local tuning properties.
Thank you Narflex aka Jeffrey
Network encoder tuning issue. Dahrl Hardware Support 3 01-26-2018 06:54 AM
Network encoder question - HDPVR on Linux sgx2 SageTV Github Development 1 05-09-2016 08:26 PM
HDPVR & SPDIF Tuning Problem Deano Hardware Support 0 12-17-2011 06:21 PM
Network encoder delay between tuning and playing michaeldjcox SageTV Software 8 04-18-2009 01:18 PM
HD-PVR as network encoder problem phelme Hardware Support 9 07-28-2008 12:38 AM
