Old 08-02-2014, 12:25 PM
Robert Wise's Avatar
Robert Wise Robert Wise is offline
SageTv Server no longer visible
I was getting a Red X on one of my Tuners, so I assumed the Tuner was hung up, but it turns out that the STB was frozen. So I fixed this issue and restarted the Server, but now it is not visible to my client or the HD 300.
I noticed that my HomeGroup was hosed, so I had to recreate it on the Server and the Client, but this did not solve my issue. The Server IP has not changed and I can share files between the two machines. There is no firewall on the server and turning off the firewall on the client made no difference. I have restarted the SageTv Service many times.
I suspect a Windows update on the XP machine (Server) may have started this issue.
Moved Server to Windows 7 - no longer visible to client Robert Wise SageTV Software 14 10-24-2011 07:28 PM
7.1.9 RC XP SP3 client no longer can connect to server Shield SageTV Beta Test Software 2 06-16-2011 07:26 PM
HD300 no longer seeing server Robert Wise Hardware Support 5 02-17-2011 09:47 PM
EPG no longer on server mcaron1234 SageTV EPG Service 0 12-02-2009 06:08 PM
SageTV not visible in VNC/Remote Desktop/PCAnywhere ??? Stuntman SageTV Software 7 08-03-2005 07:28 AM
