Playing HD PVR files with Media Player
For HD PVR recordings made in the .ts format, I have had limited success playing them with Windows Media Player. Does anyone have any codec suggestions for doing this? At the moment, I am using the Vista Codec pack but am having some problems with audio sync.
VideoLAN is fine for audio sync, but video playback is nowhere near as good as Media Player, so If I can get the audio synced, then it would be great to have a stash of HD quality files on the laptop |
Have you installed the Total Media software that came with the HD-PVR on the laptop? I suspect that would load in the correct codex. Then it is just a matter of getting WMP to use those codex.
i5 quad core server with about 10tb of space currently SageTV v9 (64bit) Ceton InfiniTV ETH 6 cable card tuner (Spectrum cable) OpenDCT HD-300 HD Extenders (hooked to my whole-house A/V system for synched playback on multiple TVs - great during a Superbowl party) Amazon Firestick 4k and Nvidia Shield using the MiniClient Using CQC to control it all |
MPC-HC should play them fine, and I'd never, ever, ever install a codec pack.
Plugin: Tag parser & media player for DRM Windows Media | GKusnick | SageTV Customizations | 133 | 03-19-2009 05:38 AM |
Playing Media Files with Sage Offline | wayner | General Discussion | 2 | 03-03-2009 07:57 PM |
Playback Exception Error (-4, 0x80040217), playing HD-PVR files | bigbill | SageTV Software | 5 | 01-02-2009 10:20 PM |
How do I get the internal media player to use a specific decoder JUST for MOV files? | mkanet | SageTV Customizations | 0 | 04-23-2007 06:50 PM |
playing back media files to my TV | ViAo | SageTV Software | 4 | 10-21-2006 01:49 PM |
