Old 03-10-2010, 07:51 PM
Podmodder Podmodder is offline
Exclamation HELP Error (-3,0x800070043) and Error (-5,08007000e)
i get the sage.PlaybackException Error (-5,08007000e) There was a problem rendering the audio portion of the content for playback over and over every second until i restart my pc, then it works until i watch a recording then it breaks again and i have to reboot again.
Sometimes it the sage.PlaybackException Error (-3,0x800070043): There was a problem accessing the filesystem for capture.
i have uninstalled and reinstalled twice and reinstalled all my codecs. this is on a brand new pc i just built on friday. all was well on my previous pc.
WIN 7 ULT 2 tb msi board intel core 2 duo 2 gigs ram, WAY better than my old P3 with WIN 7 except for this, really getting tired of rebooting so i can watch something different
EDIT: if it is recording something at the time, the recordings turn out fine with no problems...
Old 03-10-2010, 09:21 PM
ok, so i can get rid of the no audio error if i go and change the audio renderer from default to something else then back again but then i have no sound until i reboot. it is doing now everytime i change the channel getting reall frustrating...
Old 03-11-2010, 08:07 PM
i got tired of it not working, so i went back a restore point and now all is well, so a windows update must have broken it, so no more windows updates for me.
Old 03-20-2010, 12:12 PM
well, its broken again. i read on this thread that it might be a sharing issue but there wasnt really a solution explained. can any one help?
Old 03-21-2010, 05:43 AM
Savage1701 Savage1701 is offline
Did I miss your system profile on your posts? I was trying to figure out what type of recording you were doing that was causing your issues. Maybe I missed it. Are you recording with an analog cable card, QAM, OTA ATSC or HD-PVR?
Most of my problems of that type came from using an HD-PVR and such, so I wanted to know what your recording source was.
Ooops - now I see some of your system, but what was doing the capture?
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR.
Last edited by Savage1701; 03-21-2010 at 05:44 AM. Reason: Saw part of your system in first post.
Old 03-21-2010, 11:53 AM
I have a Hauppauge WinTV PVR PCI II 150. I was thoroughly "peeved" at it last night so I did an entire re-install of windows 7 and all is well for now, but it worked ok for the first month last time too so a few tips for "just in case" would be ok too I guess
Old 04-01-2010, 07:05 AM
One other thing - I use a ethernet-controlled power strip. I have my BIOS set to restore on AC loss, and Sage set to boot to tray on startup. I also have my HD-PVR on that strip. About every third day I power off the system via shutdown, and then I kill all AC to it and to the HD-PVR for about 30 seconds. Then I restart the HD-PVR, and in about 10 seconds switch the Sage Server's outlet back on (All controlled by a macro feature the PDU has in it). I've had zero problems with any tuner for about 2 months now.
Old 04-02-2010, 05:53 PM
if it starts acting up again i'll try that, mine is all in one box though hooked up to my tv, no server
HD-PVR Error -4,0x8007001f Error in Playback Xiphoid Hardware Support 13 02-28-2010 11:56 AM
Error (-3,0x800070043) PRKIDD SageTV Software 2 02-13-2010 08:45 PM
6.4.5 doesn't install: error 1904 DLL registration error snipeman SageTV Beta Test Software 9 07-11-2008 02:31 PM
Playback Error (-4,0x80040217) SAGE 6 Error dealsdyker SageTV Software 5 01-02-2007 08:02 AM
ERROR: sage.PlaybackException: Error (-4,0x8004022f): Boxpin SageTV Software 3 08-15-2006 08:23 PM
