Old 08-15-2011, 07:06 AM
Can you edit the tv fanart location manually
I've been using Diamond and BMT for along time time and have never had this happen. The fan art for some shows aren't showing so I used the web interface to see what is going on. It seems that BMT is showing the wrong location for the fan art. It has the correct directory C:\Fan Art but for example Rescue Me is showing Season 5 and 6 are in directory C:\Fan Art\season 5 and 6 instead of C:\Fan Art\TV\Rescue Me\Season 5 and 6. It does have Season 7 correct but not the other two. Is there some way to manually correct the problem? I tried turning off the season option but that didn't seem to help. How does the season option affect BMT?
Old 08-15-2011, 07:10 AM
It appears that there isn't a MediaType associated with the media file, which is required for the fanart to work. I'm making some changes to the fanart over the next few days to make it more forgiving when there is a missing mediatitle or mediatype. It might fix this issue for you.
Old 08-15-2011, 08:02 AM
Thanks stukless, as always you are a big help.
Fanart Location wayner Batch Metadata Tools 3 05-16-2011 05:32 PM
Unable to save fanart manually brewston Batch Metadata Tools 9 03-14-2011 04:25 PM
New HD300 and fanart location? Brent94Z Sage My Movies 5 10-11-2010 12:31 PM
manually edit video metadata loomdog32 SageMC Custom Interface 8 01-04-2009 12:34 AM
Is there a way to manually edit the Sage database mikesm SageTV Software 25 06-13-2007 12:18 AM
