Old 11-17-2009, 08:21 AM
bsung bsung is offline
Finding Recording Errors
Is there a way to find recordings with recording errors? So I know that the system messages tells me which ones recently had problems (almost always due to the occassional HDPVR lock up). But I'm using the malore menus and don't see a way to filter by recordings with errors. Maybe in SageMC? For now, I have to hit play and visually see which ones have the dreaded red sections in the bar at the bottom. I wanted to be able to click on ones with errors, find future recordings, and reschedule the recording without having to flip from system messages to search for future airings. If it were possible to have Sage automatically try to record future airing when an error is detected that would be better. Also great would be if upon detecting a certain number of errors from the HDPVR, Sage would assume it wasn't available anymore and only use the remaining tuners. I have 3 HDPVRs (despite the issues, it's still a great product) and I'm pretty sure that when one locks up, the others always still work fine.
Old 11-17-2009, 08:30 AM
Usually the ones with the red sections means it actually stopped and restarted recording the file. If you look in the Recordings directory with file explorer you should see multiple files for the same recordings.
Recording Errors - Unknown Cause jillsy SageTV Software 0 03-06-2009 12:44 AM
Strange favorites recording errors Griff SageTV Software 4 06-27-2005 04:23 PM
Finding a MediaMVP krwren Hardware Support 2 12-02-2004 02:28 PM
Finding My Music Whatsamobo SageTV Beta Test Software 23 04-30-2004 01:00 PM
Mpeg recording errors ripple SageTV Beta Test Software 6 03-30-2004 02:25 PM
