Old 10-18-2019, 02:33 PM
Recommendations for new hardware
I'm thinking of replacing at least the motherboard and CPU on my 2010 vintage SageTV server. I'm currently running a ASUS P7H55D-EVO LGA 1156 Motherboard, Intel Core I5-661 overclocked to about 3.8ghz, Windows 7. I'd like to go to a current hardware platform with Windows 10 64 bit, maybe Pro.
I have 3 3.5" HDDs and one SSD.
This is my current mATX case, which I might reuse:
Do these wish lists look likely to work? Also, are onboard USB ports still a problem like they were many years ago? The Mini-ITX board doesn't have any slots except the one for the GPU card.
mATX Intel:
https://secure.newegg.com/Wishlist/S...EIG6QV0A%3d%3d
Mini ITX Intel:
https://secure.newegg.com/Wishlist/S...7wPOgHYcfgA%3d
mATX AMD:
https://secure.newegg.com/Wishlist/S...orAxTSXA%3d%3d
The storage configurations on these cases use inverted and vertical positioning, a bit unnerving but probably not an actual problem.
ASRock B450M Pro4 AM4 mATX AMD Motherboard, AMD Ryzen 5 2600 3.4GHz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD - Black SN750 NVMe SSD 250GB, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, HD-PVR2, WinTV-quadHD USB, Windows 10 64bit
Old 10-20-2019, 08:29 AM
SHS's Avatar
SHS SHS is offline
Look nice
Old 10-20-2019, 09:29 AM
Originally Posted by SHS View Post
Look nice
Thanks! I put this together February 2010. I tried unplugging my tuners from the USB card and plugging into the motherboard USB. Not a problem. I'm going with this build: https://secure.newegg.com/Wishlist/S...cJhbOD3RbHw%3d
Old 10-20-2019, 01:49 PM
SHS's Avatar
SHS SHS is offline
I like Silver Stone Technologies CS280B P NAS Chassis but to over price for me.
Old 10-21-2019, 03:09 PM
My big puzzle lately is Intel vs. AMD. It's almost like Ford vs. Chevy these days.
Old 10-22-2019, 05:39 AM
SHS's Avatar
SHS SHS is offline
I know I really wish AMD would get it act right with linux.
It REALLY boil down to what app you plan on using it with.
Intel has the better support when come Linux transcoding with it QuickSync with it integrated video.
AMD has better price and more steam count then Nvidia with it lock 2 steam count unless you can get the mod driver which unlock this with Windows.
In just case of SageTV I think and Ryzen 3200G or 3400G better value being all those Benchmark with Core i3-9100F are using discrete GPU as this CPU doesn't have an integrated video card which add more cost unless you got a newer GPU.
Old 10-23-2019, 09:52 AM
I have an NVIDIA graphics card that I plan on using. There is a Ryzen 5 2600 bundle at Micro Center for $159.99 that's tempting. Also has the only AMD micro ATX board that I like.
Old 10-23-2019, 09:56 AM
tvmaster2's Avatar
In comparison to the old, quad-core Pentium I’m running for my Sage server, how does this Ryzen compare? I too am thinking of building a new Sage box, but am nervous investing any money as I watch key-developer after key-developer abandoning the Sage platform....
Old 10-23-2019, 11:35 AM
Originally Posted by tvmaster2 View Post
In comparison to the old, quad-core Pentium Iím running for my Sage server, how does this Ryzen compare? I too am thinking of building a new Sage box, but am nervous investing any money as I watch key-developer after key-developer abandoning the Sage platform....
I'm sure it's faster. It also probably doesn't run Windows 7. My major motivation is the spinning cursor on the recordings screens. My playback is still pretty snappy.
Old 10-23-2019, 12:12 PM
SHS's Avatar
SHS SHS is offline
That not bad deal
Old 10-23-2019, 01:45 PM
Do you need a discrete video card? I am not as sure about AMD processors but Intel CPUs have more than enough onboard power for displaying video.
Old 10-23-2019, 01:58 PM
SHS's Avatar
SHS SHS is offline
Yes it has more the enough onboard power for displaying video as I have really old AMD APU A10-5800K
Old 10-24-2019, 03:00 AM
Yes if it's an APU. The Ryzen 5 2600 doesn't have an integrated GPU.
Old 10-24-2019, 09:31 AM
SHS's Avatar
SHS SHS is offline
I refer to more update APU like Ryzen 2200/3200G, 2400/3400G as my old AMD APU A10-5800K dose just fine but which is many gen old vs the new APU
Old 10-27-2019, 02:45 AM
I built the thing. Still trying to sort it out. Can't find favorites, Eventghost is FUBAR and every show lost TV station info.
Old 10-29-2019, 07:10 AM
All good now. USB-UUIRT drivers needed replaced. Reinstalled without Sage.properties.
Old 10-29-2019, 11:26 PM
tvmaster2's Avatar
Do you know of a good, not obvious, link for learning how to install and use a USB-UIRT? All the typical ones havenít helped me - Iím UIRT-slow.
Old 10-30-2019, 03:01 AM
This saved me. The SageTV installer didn't really install the drivers, probably Windows blocked it. https://forums.sagetv.com/forums/sho...&postcount=191
Now if I could just figure out how to lift my EventGhost tree out of my old hard drive!
Old 10-30-2019, 09:47 AM
JustFred JustFred is offline
USB-UIRT currently has a limitation: it can't talk to 32-bit and 64-bit programs at the same time. If running the Sage-x64 service, you'll need to install/run the 64-bit version of EventGhost.
Old 10-30-2019, 11:39 AM
Thanks for the reminder. I asked Eventghost for 64 bit years ago. I was able to use it when I was using the IR blaster that came with the HDPVR-2 to change channels.
New Server Hardware Recommendations bbenkstein Hardware Support 6 11-13-2011 12:14 AM
Hardware Recommendations? Underfunded Hardware Support 3 11-21-2008 01:54 PM
Hardware recommendations for 60 tuners shahfar Hardware Support 35 04-04-2008 10:42 AM
Looking for recommendations for new tuner hardware neilbradley Hardware Support 1 06-12-2007 08:11 PM
Considering a switch from Tivo, Hardware recommendations? abbott_m Hardware Support 14 01-03-2005 09:46 PM
