Old 03-05-2010, 11:41 PM
davenlr davenlr is offline
Program Guide - More shows per screen?
Ive searched the forums and the faqs, but cannot find an answer to this.
Currently my program guide shows only 5 channels at once, and 1.5 hours.
Is there any way, using the 1080p resolution, to get the Media Extender (or Sage) to display more channels per screen, and more time per channel?
Sage 7 on Win8.1 i7 6TB server, 1 gig network, HD Homerun
Old 03-06-2010, 12:22 AM
xxLJLxx's Avatar
xxLJLxx xxLJLxx is offline
Try hitting your Options button while viewing the actual grid style guide. After that, "Display Options" are what you want to click on. You can then change the number of rows and columns and that should give you the flexibility to get it setup how you want.
Old 03-06-2010, 08:46 AM
Thanks.
program guide
Program Guide Filtering of Junk Shows Pumpkinhead SageTV Studio 7 10-31-2009 05:42 PM
How to disable the popup window in the program guide? How to keep the program guide? metropole SageTV Software 8 05-18-2006 06:25 PM
Program Guide/Searching For Shows On another Computer FormatC: SageTV Software 11 05-02-2006 06:29 PM
Any way to keep program guide from displaying past shows? jhendrix SageTV Software 3 04-20-2006 01:32 AM
Can I add an extra line on the Program Guide screen? centralohioguy SageTV Software 4 12-09-2005 10:27 AM
