Old 06-23-2010, 11:53 PM
setherd setherd is offline
Unhappy how do you enable playback of ISO files?
I installed virtual clone drive.
I have ISO files in my path.
I can't see them with sagetv.
I've searched the forums but haven't read a clear answer.
is there a step I'm missing?
Take care,
Seth
Old 06-24-2010, 08:33 AM
UgaData's Avatar
UgaData UgaData is offline
http://forums.sagetv.com/forums/showthread.php?t=48502
You really shouldn't have to do anything to enable ISO support. Read through the above thread. Just in case, there is a line in the Properties file that lets Sage "recognize" file extensions.
Which Sage 7 beta are you using. The first beta had a problem with ISO files if you were running the SageTV service. It has since been fixed.
Old 06-25-2010, 08:03 AM
yes I read that thread but still nothing.
Take care,
Seth
Old 06-26-2010, 05:19 PM
well I can see the iso files browsing the file system but when I play them, I get the spinning circle then it goes to live TV....weird
Take care,
Seth
Old 10-30-2010, 10:10 PM
rxnelson rxnelson is offline
I have had this happen as well. I think if your path has a space in it either sage or VCD doesn't play well. I had a folder called "blurayisos" that worked and one called "bluray isos" that went to live tv....this was over a unc share. I didn't do much testing but removing the space seemed to fix it.
iso
How to enable DVD .ISO support for Sage MrFusion SageTV Customizations 30 05-16-2010 05:11 AM
How do I enable subtitles in DIVX avi files? nicholsona SageTV Software 5 12-09-2009 12:22 PM
HD200 playing BluRay ISO files HeadHodge SageTV HD Theater - Media Player 1 09-05-2009 12:57 PM
.ISO Files: Making More Readily-Available? PeteCress SageTV HD Theater - Media Player 6 04-12-2009 07:52 AM
Looking for help with VOB, ISO, IMG, & MDS files. BugMan SageTV Media Extender 31 04-23-2006 12:22 PM
