Old 03-06-2005, 06:57 AM
DKT DKT is offline
Computer won't wake up anymore from S3
I have SageTV version 2.1.10 installed and it was working perfectly for many months - waking up to record a show and then going back to sleep.
Now the computer will not wake up properly. It just hangs with no monitor and the HDD light on constantly.
I went into the BIOS and turned the S3 off, rebooted, and then turned it on and it woke up properly once, but then again hung.
I'm now stuck with S1.
Any help would be greatly appreciated.
Old 03-06-2005, 01:50 PM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
It won't wake at all, or it hangs? The issue I was having was that SageTV would indeed wake and record properly, but I could not get the Windows GUI back w/o a reboot.
I'm working w/ Intel support to see about it.
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 03-07-2005, 09:11 AM
DKT DKT is offline
I guess the best way to put it, is that it attempts to wake but never does. The fans will come on and the HDD light stays on continually, but that's it. No recording, screen, and it will not shut itself off.
Old 03-07-2005, 09:39 AM
Yeah, sounds like it is hanging when trying to wake. Are you positive you aren't getting recordings?
Old 03-07-2005, 10:39 AM
DKT DKT is offline
I am certain. I turned of SageTV service, closed SageTV and let the computer go to sleep. It would not wake up with nothing running, so the conclusion I came to is that it is not Sage related.
I have reset power management in the BIOS to S1, and that is working fine (wakes up to record and then goes into S1 when it times out). This is an adequate solution, except the fans (3, CPU, Power Supply, and the case fan) continue to run, which is a little noisy and consumes more electricity.
Old 03-07-2005, 11:52 AM
hmca's Avatar
hmca hmca is offline
Have you tried reverting XP to just before the problem started. That has fixed a number of problems for me while was mucking about with settings and such.
XP SP1A; Sage V5.04; ; IN-WIN BT611T Case, custom full height conversion; Asus A7N8X VM/400; AthlonXP 2000, Palomino Core; Thermaltake Volcano 12 heatsink w/ sucking 80mm squirrel-cage fan, Zalman Fan-Mate on 5V, min setting; PNY 512MB PC2700; Gigabyte 7600 fanless, 256MB; 2 x Samsung Spinpoint 250GB; 3 x PVR250MCE; 3 x Hughes E8 OTA HD downconverters; External Fortron 400W Silent w/Performance-PCs.com extension cables; modified ZM-MC1 to 7V & 5V; Evercool 60 & 80mm fans @ 7V; StreamZap Remote
Old 03-07-2005, 11:57 AM
falchulk falchulk is offline
This man is correct. System restore is the best way solve a problem like this.
Old 03-14-2005, 04:23 PM
DKT DKT is offline
I tried a system restore over the weekend and it didn't correct the problem, so I'm stuck with S1.
I think the only remedy is a new motherboard (or possibly flashing the BIOS, but not sure I want to do that).
The system is quiet enough that I think I'll stick with what I have for a while until I get motivated to change out the motherboard and reinstall XP, etc.
