Old 11-28-2007, 12:03 PM
DFranch's Avatar
DFranch DFranch is offline
Can the HD extender wake the server from sleep?
I am wondering if the new HD extender will be able to wake the server from sleep? I seem to recall reading that the SD extender would not do that. I would really like to be able to sleep the server and only have it turn on when it is time for a recording, or the extender is turned on. I currently cannot sleep my server because it screws up FSE.
SERVER: Gigabyte EP45-UD3R | Intel Core 2 Duo 2.67 Ghz | Geforce 8500GT | 4 Gb Corsair DDR2 1066 |
2 Hauppauge HVR-2250 | Win 7 64-bit | Sage TV 6.6.2 | 1.6TB (4 Drives) |
Client: Sage TV STX-HD100 HD Extender
Old 11-28-2007, 04:35 PM
mayamaniac's Avatar
I doubt the HD extender has this feature or capability. But as an alternative, you can wake the server from standby via a remote if you have an IR receiver such as a USB-UIRT and girder, if your motherboard supports wake from USB.
Mayamaniac
Old 11-28-2007, 10:44 PM
DFranch's Avatar
what about wake on lan. would that wake the server when the extender tries to access it?
Old 11-29-2007, 09:47 AM
Rogier21 Rogier21 is offline
Depends if the software supports it. But it SHOULD be able to do that with some addons? Just send out the MAC address from the server a couple of times and WOL should activate the server.
Old 11-29-2007, 11:28 AM
CollinR CollinR is offline
The functionality would have to exist inside the application package loaded on the extender. This might even be unintentionally possible through a feature of the new extender that allows you to select servers.
Can't decide on HD source? akenis Hardware Support 20 05-23-2007 07:07 PM
HD Media Extender - Exactly When ? daz19 SageTV Media Extender 46 05-23-2007 01:51 AM
SageTV java issues jayemdae SageTV Linux 3 05-20-2007 02:55 PM
Registering client licenses / Extenders not connecting Risasi SageTV Linux 2 09-13-2006 05:36 PM
Media Extender Server menu option mrblack SageTV Media Extender 4 02-19-2006 01:04 PM
