Batch Metadata Tools This forums is for discussing the user-created Batch Metadata Tools for SageTV. |
Jetty download failed, BMT won't install
I'm putting together a new server and having problems getting BMT installed. I installed SageTV v7 and using the plugin manager tried to install BMT. During the installation it failed to download Jetty. Figuring that all the plugins that use Jetty use the same version, I downloaded Jetty seperately, then install the Web interface plugin and finally went back and tried to install BMT again, which said it was successful.
The problem is that now the web applications page on the server (serverip:8080/apps) shows BMT as failed even though the plugin manager says it is installed. So I went back and uninstalled all the plugins, restarted, and tried to install BMT again. This time it went through the download process and said succeeded.. but still shows as failed on the apps webpage. What am I missing here? Is there a way to manually enable it, or at least steps to clean it out properly so I can install it again successfully? I would prefer not to have to reinstall SageTV again if possible... |
Once bmt is installed on the server you will need to restart the sagetv server in order for it to work properly.
Guess the 3rd time was the charm. Had to uninstall all the plugins, restart the server, install BMT, restart the server, then it finally showed as installed.
Jetty install failed-Zip extraction error | dblaine2 | SageTV v7 Customizations | 4 | 06-16-2011 07:38 PM |
Broken install - can't reinstall - SMM API Failed | uberpixel | Sage My Movies | 2 | 12-05-2010 11:10 PM |
ComskipPlayback plugin install failed | hogburgs | SageTV v7 Customizations | 3 | 08-29-2010 07:51 PM |
SageTV install location drive failed | alwzn4vr | SageTV Software | 2 | 06-13-2010 07:15 PM |
Fresh Install - What do I download? | Brian B | SageTV Software | 18 | 03-25-2008 08:34 PM |
