Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 09-28-2012, 08:14 PM
Joebob Joebob is offline
Gemstone API Failed
I just updated from Diamond to Gemstone. The Gemstone GUI won't load presumably because the Gemstone API is listed as Failed. I have tried uninstall/reinstall and that didn't fix it.
I have switched back to Diamond Legacy for the time being.
Old 09-29-2012, 06:27 AM
jusjoken jusjoken is offline
If I had to guess I would suggest that the download or extract of the Gemstone JAR file to the SageTV jars folder failed somehow. Make sure you have uninstalled gemstone and then try closing sage and if on the server then stop the service and delete the gemstone.jar and then reinstall gemstone and let us know how it went.
k
Old 09-29-2012, 12:16 PM
Also, the "failure" should be listed in the sagetv_0.txt log file, since SageTV will log the reasons why it cannot load a plugin.
Gemstone FAQ jusjoken Gemstone for v7 9 05-24-2013 12:57 PM
Gemstone UI Addon and Theme jorton Gemstone for v7 126 10-21-2012 08:38 PM
Gemstone questions pjpjpjpj Gemstone for v7 7 09-13-2012 10:14 AM
Gemstone Not compatible wayner Gemstone for v7 2 09-07-2012 09:35 PM
Automatic Metadata Failed (Code 10100) IMDB: Failed to parse providerDataUrl: mkanet Batch Metadata Tools 2 10-12-2010 03:22 PM
