Old 09-14-2008, 06:53 PM
pianoman99 pianoman99 is offline
Is Hauppauge hvr-1250 Analog Capture Supported?
I am able to get QAM capture working, although there are some strange interactions between the hvr-1250 and my hd-pvr with respect to the program guide. (That topic is enough for another thread.)
I have been unable to get analog capture working. I get the following error message when trying to set up the analog device:
"(-6,0x80004005) There was a problem setting up hardware video compression"
At first, I only installed the Hauppauge driver. When the hvr-1250 didn't work in sage, I then installed the WinTv software. WinTv is able to record the analog channels but Sage still gives the error message.
Has anyone managed to get this card to capture analog video?
Old 10-24-2008, 04:31 PM
EdwardATeller EdwardATeller is offline
I have exactly the same problem.
STV 9.1.5.683 / Vista Premium / Compaq Presario SR-5550F / AMD Athlon 64 X2 5400 / nvidia GeForce 8400GS / 3 GB DDR2 / 500 GB SATA / 1 TB SATA / M2N68-LA Motherboard / 2 x Hauppauge HVR-1250 / Hauppauge HVR-1600 / 2 x STX-HD100 / OTA
Old 11-24-2008, 06:41 PM
Jetracers Jetracers is offline
Try this it was given to me by sage support and made it so my analog side would work
Try making this registry setting, and then let me know if it works:
HKEY_LOCAL_MACHINE\SOFTWARE\Frey
Technologies\Common\AdditionalCaptureSetups\Hauppauge WinTV 885 Video
Capture\CaptureMask=0x8100
(it'll currently be set to 8800, so change it to 8100)
SageTV Support Team
SageTV, LLC
Setup: AMD Phenom II x4 940@3.0 GHz Processor: Gigabyte GA-M750SLI-DS4 Motherboard: 4 GB Corsair PC2 6400 Memory:
OS Drive 320 GB Seagate hard drive: Recording Drives 2x500 GB WDCaviar 64k Clusters, 1x1.5TB Seagate 64k clusters, 1x320 GB Seagate 4k Clusters, 1x250 Seagate external USB 32k Clusters:Tuners(w/5 setup for recording HD; 2 for SD content): 1 Hauppauge HVR-1600, 1 HDHomeRun, 2x Hauppauge HVR-1250; XP Pro 32 bit, SageTV V6.5.9 SAGEMC V6.3.8a
Old 11-24-2008, 09:01 PM
CollinR CollinR is offline
Remember HVR1250 is a software encoder.
Sage TV windows and Hauppauge HD PVR htpcmaniac Hardware Support 10 09-21-2008 09:09 PM
Hauppauge 1800 record dual analog? CaptSammy Hardware Support 3 02-09-2008 12:06 PM
Bad Tuner Index + Mpeg4 Extended play not supported - How can I clear these up? Shield SageTV Beta Test Software 5 08-30-2007 11:00 PM
Successful SageTV Install on Via Epia System with Hauppauge 350 gazer Hardware Support 0 03-23-2006 01:48 PM
