Old 10-19-2008, 12:33 PM
MarkV MarkV is offline
Custom convert string being reset
I just discovered the convert option and I'm trying to convert files to psp format. Unfortunately, the sage properties files have the wrong ideal resolution and should support 480x272.
I've stopped sage services and sage client and changed the values to 480 272. I restart sage services and the client and they change back to the defaults. What am I missing ?
I'm using the latest release of Sage and am running on
Vista 64. And I am saving the properties files as administrator. After editing, I reload and examine them. They're fine. Start sage and they flip back. I'm editing the PSP lines that come with the default sage properties.
Mark
Old 10-19-2008, 01:04 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
All the supplied profiles get reset at startup. You need to add a new profile with your settings.
John
Old 10-19-2008, 01:55 PM
Thanks. I'll give that a go...
Worked great. More questions - how does one tell it to do a two-pass conversion for higher quality ? Does transcoder/enable_multipass_encoding=true force it for all conversions ?
Still looking thru the forums for info about the transcode string attributes.
Old 10-20-2008, 06:02 AM
I altered the width and height to 480 and 272 and increased the bit rate from 768000 to 1024000. The files (renamed to mp4) will not playback on my psp. Back to Nero 8 until the bugs get worked out
