Make Harmony remote *not* like HD300?
Hey Guys,
I know most of you likely select the HD200 in Harmony remote setup. However, I want to run both the HD300 and my server HTPC in a similar location. I have them both setup and working but I can only run one at a time because the HD300 signals are picked up by my USB-UIRT and the USB-UIRT signals are picked up by the HD300. Since my remote commands are the same, trying to control one affects the other... not good ![]() Any suggestions? My thinking is to setup my USB-UIRT to use remote commands completely different than the HD300 remote and then program the Harmony accordingly. Have any of you done this and have a good recommendation on what to use for the Harmony setup that won't use the same commands as the HD300? Thanks! |
Since the IR codes are the same, I think you are going to have issues unless use a RF repeater for one device. There may some way to change the IR codes in Sage but I have never ran across any such item.
Google?? Facebook?? MySpace??
-=[If you don't pay for the product, chances are you are the product]=- |
If no "proven" ideas, I'll probably just grab one of my older remotes that has similar keys and map all those to the Harmony and map the Harmony to the USB-UIRT. That'll take me a little while so was just wondering if there was a better way ![]() Thanks! |
I just picked a Panasonic stereo remote of some sort for my Harmony because I don't have any Panasonic equipment. Just rename the device to SageTV and then teach Sage the codes. Keeps it from interfering with anything else I have set up.
Thanks! I don't have any Panasonic stuff either so that sounds like it'll work
Oh the other nice thing is IIRC none of Panasonic's remotes use toggle codes. I know for a fact the one I chose doesn't. That way I only have to program one code instead of two for each button
I have both an HD200 and an HD100 in the same room (for watching two football games at once). I removed the commands for the HDx00 remote on the HD100 and removed the commands for the Hauppauge Remote from the HD200 so now I use my Harmony remote (with the HDx00 codes) for my HD200 and use an old crappy Hauppauge Remote for the HD100. Once my new Harmony One comes (I ran out of devices on my 700) I am hoping to program in the Hauppauge remote in as well so I can do it all from my Harmony.
The only thing I am having an issue with is removing the "select" command. Ho Hum.
Thanks for the suggestions guys, I hope to have some time to get this setup mid next week.
One thing that I'm having issues with on my own Harmony One remote is the speed at which the Harmony One sends out another command. This has been causing me to use my HD PVR remote for my HTPC because I can't get the Harmony to "speed up". I realize that there is a setting in the Harmony setup for delay between sending commands but I have changed this several times and have it all the way down to 0 and it still behaves like it is a 1/4 second or so (no changes from the original setting). Meaning, with my HD PVR remote and on the main menu with the top menu item selected, I can hit the "down" button and as fast as I can hit that button it'll move down. However, with my Harmony, it is definitely being "held up" because no matter how fast I press the button it is an obvious delay to the next item that is the same as the previous. If it "remembers" 3 or 4 presses, it executes those way after I stopped pressing buttons. Anybody seen this or have any ideas? I'm within my 90 day period so if nobody has seen this, I'll call tech support and see if they have any pointers. Thanks! |
I think some of the devices on the harmony site have delays built into the remote codes, so changing the settings in the harmony doesn't make any difference.
Raising a support ticket with logitech would probably be useful as they can make custom changes to your stored config if needed, which you then just update into your harmony. Overall I found the harmony is slower than normal remotes but for most use it's acceptable. I've found the biggest pain is switching everything off, waiting while it goes through each device, or the inability to support short press and long press on the same button. My sat receiver can have multi-function coloured buttons based on the hold time. The big problem with AIO IR remotes is that they're IR. Advantage is they're cheap and cheerful. RF to Serial should make things nicer, but that's a whole different price range, both for the remote and the components with serial control. |
HD300 with logitech harmony remote | sflamm | Hardware Support | 8 | 10-06-2010 11:52 AM |
HD300 remote codes in Harmony database | phelme | Hardware Support | 1 | 09-20-2010 01:34 PM |
Harmony Remote | Hilbe | SageTV Mac Edition | 7 | 02-20-2009 11:05 AM |
Harmony Remote | vexhold | Hardware Support | 2 | 12-09-2008 06:37 PM |
Harmony Remote(s) | Jason | Hardware Support | 0 | 11-09-2004 10:34 AM |
