Old 05-11-2006, 11:16 AM
hummedan hummedan is offline
Question Picture in Picture
Does anyone know of a customization that allows you to view picture in picture or have multiple channels playing at the same time?
I am wanting to add a PVR500 to my system (PVR350 alread installed) and I was curios if I could have three shows playing simultaniously. (Thinking ahead to football season!)
Old 05-11-2006, 11:34 AM
No. Not at this time.
Old 05-11-2006, 11:35 AM
GKusnick's Avatar
GKusnick GKusnick is offline
Adding tuners will give you the ability to record multiple channels simultaneously, but that's got nothing to do with how many media streams you can play back simultaneously, which is a completely separate function. At present, Sage can play back just one stream at a time (not counting MVPs and Placeshifter clients).
-- Greg
Old 05-11-2006, 11:52 AM
Any chance of running multiple instances of Sage on the same computer?
Old 05-11-2006, 12:11 PM
geogecko geogecko is offline
Then you'd have audio problems, wouldn't you?
I think Sage needs to come up with something like that though...seems like it wouldn't be too hard. Just trying to figure out the controls would be the hard part.
-Jason
Old 05-11-2006, 01:45 PM
ldavis ldavis is offline
What about hardware acceleration? How could two streams be decoded at once. With SDTV one could use the CPU but if you are watching HDTV on both channels, that is going to be very difficult unless you have a really fast computer.
Old 05-14-2006, 12:51 PM
hechacker1's Avatar
hechacker1 hechacker1 is offline
Send a message via AIM to hechacker1
Hmm.. if SageTV is using standard directshow stuff to display it's video, then I see no reason why SageTV couldn't play back more than one stream.
I can easily open about 4 or 5 videos at the same time that SageTV has created. However though, I have hardware decoding and a fairly fast RAID system, otherwise my hard drives wouldn't be able to keep it up.
But yeah, PIP should be feasable for those with two tuners.. or actually, even for just a preview of a previously recorded show while watching something else.
Proof it could work.
http://ordorica.org/pictures/forum/decode.jpg
Old 05-15-2006, 01:08 PM
digitalgm digitalgm is offline
Not to get off topic but I have to ask. What theme/package are you using on your computer? It looks very different from mine.
Currently building the mother of all SageTV Installations .... XXL SageTV
Summary: 40 Analog Tuners, 10 OTA HD Tuners, 3 Sat HD Tuners, 20 Client HTPCs, Dedicated Commercial Skipping Server Wish me luck!
Old 05-15-2006, 03:55 PM
mayamaniac's Avatar
It's Gui Air: http://www.neowin.net/forum/index.php?showtopic=433372
Mayamaniac
Old 05-15-2006, 07:44 PM
lotusvball's Avatar
lotusvball lotusvball is offline
This can't really be that difficult. Other products have this ability. MythTV for example.
http://www.mythtv.org/modules.php?name=MythFeatures
Intel Core Duo 2.5mhz, 2gb RAM
Windows Home Server, Sage 7 beta
2 Hauppauge PVR-250, 1 PVR-500 MCE
1 HDHomeRun
4TB Storage, GB Network
2 MVPs, 1 HD100 & 1 HD300
Old 08-04-2006, 12:14 PM
gndprx gndprx is offline
Digging up an old thread....
Any word on PIP support? This seems to be a big deal for the WAF here as I add more and more to the Sage box.
I know myth is doing PIP without much difficulty, but I chose sage for the media extenders...so I'm sticking it out hoping for PIP sometime in the near future
Old 08-04-2006, 12:41 PM
JUC's Avatar
JUC JUC is offline
well, with v5.1 now in private beta testing we can only wait and hope--but i'm guessing its not high on the list...
Old 08-04-2006, 12:48 PM
NEOSG NEOSG is offline
Not perfect, but If I have to have PIP, I run a placeshifter client at the same time as my sage client. Again, it's not perfect and I only use it if I HAVE to have PIP.
For example, when the US was playing Ghana and if the US hadn't played like crap, the Italy game at the same time would have been meaningful for the US team.
So, I put the US game on the sage client and watched the Italy game via the placeshifter
Old 08-04-2006, 03:30 PM
mkanet's Avatar
mkanet mkanet is offline
If I had a dime for every time i see this request...
Edit: I'd probably be a little over a dollar richer
***RIP SageTV***
Old 05-29-2007, 01:41 PM
jprine01 jprine01 is offline
Just bumping because I want Picture In Picture too and don't want to start a new thread!
Old 06-01-2007, 06:53 PM
KJake KJake is offline
I'm going to be ignorant and say, couldn't this be done in an STV?
Old 06-01-2007, 11:25 PM
mikesm mikesm is offline
Does windows support doing two mpeg decode operations on the same screen from two different sources? I'm not sure this is doable in windows.. There is only one overlay plane, and in VMR9 I don't think this works...
mike
Old 06-02-2007, 12:06 AM
nielm's Avatar
nielm nielm is offline
No. the Sage core only has a single media player engine -- only one file can be played back at a time...
While it is true that there is only one overlay, multiple simultaneous playbacks can occur in Windows. With VMR9, multiple playbacks can occur within the same rendering window with separate sizing/positioning (easily shown with graphedit -- its part of the reason it was created)
Old 06-02-2007, 04:23 AM
tmiranda's Avatar
tmiranda tmiranda is offline
I have a TV that supports PIP so for an experiment I connected two MVPs to two different sources on the TV. PIP worked fine but was not very practical since both MVPs would react to the same keypress on the remote and there is no way that I know of to change that behavior.
I suppose you could connect two full clients to overcome the MVP remote issue but that gets really expensive....
YMMV
Old 06-11-2007, 02:53 AM
CollinR CollinR is offline
Can't you also remap the MVP IR too?
IE use a different remote with one of the MVPs.
