Old 03-16-2014, 08:21 PM
hummedan hummedan is offline
PlayOn and PlayLater Recordings
Hello,
I have been using SageTV to view my PlayOn and PlayLater recordings and it has been working great.
Recently when I try to view my PlayLater recordings I get the full list and thumbnail image for the recording; however, I notice the recording length is 00:00:00 and when I try to play the recording I get the following error:
There was an error downloading C:\Users\Dan\Appdata\Local\Temp\OnlineVideo1676250370495029408.flv:
Error:
error:java.lang.arrayindexoutofboundsexception
I am unable to view any of the recordings through Sage. I can stream internet video (Hulu, CBS, etc) from the PlayOn fine.
I have gone to the temp directory and the OnlinVideo1676....flv file is not present.
I can go to the recording on my media server and it will play locally just not through Sage.
Any help you can give would be welcome!
Hummedan
Old 03-18-2014, 02:00 PM
saltlyck2 saltlyck2 is offline
Not another same here...
I'm having this same issue. Just wanted you to know you are not alone on this one. Everything except netflix plays fine. Is yours doing the same? I can play it in IE but not from sage with the same symptoms. Logs are not helping me at all.
Old 03-21-2014, 11:04 AM
No luck for me on Netflix either but I have other devices that handle that for me (Blue Ray player).
From what I have deduced it looks like the problem is with the Playon plugin for sage. I can get all my .mp4 PlayLater videos to play if I add my PlayLater folder to the Media Center Import Directories in under the general settings page under Sage Detailed Settings.
Playlater for PlayOn lotusvball SageTV v7 Customizations 12 12-31-2013 11:03 AM
PlayOn VFS wrems Phoenix 8 05-14-2013 06:06 AM
playon SteveD General Discussion 4 07-08-2011 07:12 PM
PlayOn Plugin supporting multiple PlayOn instances? vhurst SageTV v7 Customizations 0 04-04-2011 01:33 AM
Android application: PlayOn - TV Recordings, MKVs, music, pics, Hulu (Coming soon!!!) mkanet SageTV Customizations 5 11-30-2010 10:58 AM
