Old 09-10-2007, 06:03 AM
bpjen bpjen is offline
Client cannot connect to server
I am usually pretty good at this sort of thing, but I am baffled...
I recently upgraded my laptop, and cannot connect to the sagetv server with client. Here are some details:
I have been successfully running client for years on my old laptop.
I have two client licenses, one sagetv license, all v6.
I uninstalled client on old laptop.
I have restarted server a number of times.
I have tried both license numbers (both have been uninstalled).
I have tried the register command to clear the licenses.
I have deactivated the firewall, and made sure ports are open.
Just for yuks, I downloaded the trial for placeshifter, and I am able to connect without a problem.
Here is the error message I get when I try to connect using the name of the server or the ip address of the server:
Unable to connect to the SageTV server at the specified address. Please make sure you entered the name/IP address correctly and that you have enabled the SageTV Server option in Detailed Setup->Advanced on the SageTV Server. (2)
From all this, I don't think it is a license issue, but I cannot get connected to the server. Any help would be greatly appreciated.
Old 09-10-2007, 09:20 AM
You mentioned the firewall, but double check the firewalls on both the server & laptop to make sure they are allowed to talk to each other. See this FAQ for ports SageTV needs to have open. Maybe the server sees the laptop at a new address & isn't allowing the client through. (Is PS connecting over the internet or via the LAN?)
Old 09-10-2007, 01:01 PM
Thanks Andy,
Yes, I have deactivated firewall on both sides, and made sure ports are open on both sides. Since the server was already working, I know that is not a problem on the server side anyway.
PS has connected both through the internet and LAN.
Old 09-11-2007, 01:10 PM
hessjm hessjm is offline
I fought a similar problem a few weeks ago, when I upgraded my client after rebuilding the PC. After a few hours of pulling my hair out I discovered the server and client have to be the same version. Upgraded the server and I was on my way again.
Old 09-11-2007, 06:29 PM
thanks for all the help, folks.
Here's what I did:
Downloaded both new versions again
Complete uninstall on both machines
Reinstalled on both machines
Rechecked firewall settings
Restarted everything and what do you know, works like a charm.
thanks again
SageTV Client lockups and associated server side error Surtr SageTV Software 1 05-28-2007 06:55 AM
Client not finding server Doubletop SageTV Software 2 05-26-2007 03:19 PM
Client server questions restorick Hardware Support 3 01-09-2007 09:20 AM
Client cannot connect?! Jesse SageTV Software 9 08-23-2006 04:23 PM
New Server For Client davidjames SageTV Software 2 06-12-2006 10:52 PM
