Old 11-20-2009, 07:11 PM
droberts01748 droberts01748 is offline
YouTube isn't working for me
All day I read how Youtube blocked Popcorn hour users from their site. I get home and sure enough my stand alone won't play any Youtube content.
Is anyone seeing anything different?
-Dave Roberts
Hopkinton MA
Old 11-20-2009, 10:19 PM
It worked when I tried it just now. Is your firmware up to date? See the Announcements forum for a sticky with the latest firmware info and the SageTV software forum has a sticky about online video updates.
Old 11-24-2009, 07:09 PM
Brent Brent is offline
I'm not getting YouTube videos to work with either the default or SageMC STV. With any YouTube video it says "unable to determine the video file to download".
Seems like a bad sign. Anyone else getting this?
This is on SageTV Server using Windows 7 AND on an HD200 extender.
Old 11-24-2009, 10:04 PM
mayhewda mayhewda is offline
just tried as well from hd200 standalone. Very hit and miss. Some worked some had the same message "unable to determine"....and then the hd200 hung. Very unstable.
HDTV's - Pioneer Elite Pro 150FD - Plazma
- Sharp 37D62 - LCD
- Sony 40 in LCD
1 x HD200 - connected to 150FD
1 x Sage TV server
Pioneer VSX92THX receiver
Monitor one 5.1 surround speakers
Sony S550 Blueray
Old 11-24-2009, 10:07 PM
Have you referred to the stickies I mentioned above? I still see no problem.
Old 11-24-2009, 10:33 PM
oops. sorry I was at least 4 version behind on the Online update... my bad - working fine now.
Old 11-27-2009, 05:02 PM
trizio trizio is offline
Angry how to upgrade?
hello!
i also have the hd200 and have issues with youtube.
i don't have the sagetv server, but just the standalone player.
i upgraded to the latest available firmware on the hd200 update firmware menu but i still have this problem with youtube.
i tried to download the latest 6.6. firmware but i dont see the version for the hd200.
can you pls help?
thanks and regards
trizio
Old 11-27-2009, 06:44 PM
MitchSchaft MitchSchaft is offline
The answer's in the post above yours.
Old 11-27-2009, 10:45 PM
kevpriest kevpriest is offline
I was having this problem as well, so I did the firmware update, but I'm still getting "Unable to Determine the File to Download" messages for pretty much everything I try. Firmware update definitely worked, but for some reason YouTube and Google Video don't.
Old 11-27-2009, 11:32 PM
One of the stickies I referred to above states the latest online videos version. If that is not the version you have, the sticky notes that it could take up to 24 hours before another check downloads an update. Try giving it some time.
Old 11-28-2009, 10:07 AM
beta or not?
i read the stickies on the announcements.
so, are you recommending to activate the beta version updates to solve all issues? i usually do not install beta versions.
pls advise.
ciao
t
Old 11-28-2009, 12:58 PM
Yes, only the latest beta firmware versions have the required changes to handle the YouTube changes. Since you said that point wasn't clear, I tried adding a clarification to the online services sticky regarding beta firmware. Again: you may need to wait up to 24 hours for an update to be downloaded even after updating the firmware.
Old 11-28-2009, 01:41 PM
hello!
thanks. i updated and now it works.
the only thing that i find quite annoying is that when youtube hangs (dammit... how often it does!!), the hd200 hangs and i have to restart, as it just wouldn't resume the video or come back to the youtube menu.
it would be good to have the stop button active during the loading of the video, so as to avoid issues.
and when it hangs, i just have to unplug it... as there is no hard reset possible (the power button of the remote does not work too in those cases).
pls advise.
ciao
t
Youtube & Google Stopped Working For Me sjrx0213 SageTV Software 5 12-29-2007 11:20 PM
youtube no worky dustboy SageTV Mac Edition 1 09-10-2007 04:19 PM
youtube and google video not working on sageMC sevenlas SageMC Custom Interface 5 08-30-2007 09:33 AM
Where is YouTube? robk SageTV Beta Test Software 6 03-08-2007 04:53 PM
how is youtube working traker1001 SageTV Beta Test Software 6 03-05-2007 03:59 PM
