Old 11-28-2007, 12:14 AM
mightyt's Avatar
mightyt mightyt is offline
6.3.2 Main Menu Slide
I notice that when I launch 6.3.2 from the System Tray that the main menu appears, then slides in again from the right side of the screen again ... I know this is likely an animation feature, but can be annoying. Can it be disabled without turning off all animations?
Old 11-28-2007, 01:13 PM
RobJ RobJ is offline
In Detailed Setup, go to Customize, then down to 'Animation Options', then disable 'Menu transitions', leave the rest enabled. I'm guessing you are running SageTV on an older slower computer like mine. Even on my old 866 Mhz Pentium III 512MB Dell, the other animations are fine, but the 'Menu transitions' cause weird behavior, something like yours. I think it needs a little performance tuning for slower computers.
Old 11-28-2007, 09:42 PM
mightyt's Avatar
Thanks Rob ... Actually I have the reverse problem ... Dual Xeons ... it's my main system I also use as a Sage sand box for new/beta releases. The sliding menus go by so fast that whenever I launch or go the the main menu it's almost like a screen fliker ....
I'll disable it per your suggestion.
STV Import: Dynamic Customisable Main Menu (v6.4 20/Dec/2007 for SageTV 5.0/6.0) nielm SageTV Customizations 555 07-09-2014 06:36 PM
STV Import: Video Editing for Sage BobPhoenix SageTV Customizations 279 03-07-2013 01:35 PM
STV: SageMC 16x9 Version 6.x (latest dev build) dflachbart SageMC Custom Interface 6112 04-04-2008 11:16 PM
STV Import: Menu Shortcut Bars BobPhoenix SageTV Customizations 9 09-05-2006 04:46 PM
STV: SageMC 16x9 11/26/2005 Sage 4.x Version 5_10 mlbdude SageMC Custom Interface 2160 09-01-2006 03:36 PM
