Old 04-10-2010, 05:20 AM
Question HD-200 and Slingbox
Dish Network has released a new receiver (ViP 922) with an internal Slingbox.
So, I was wondering if anyone has used their HD-200 to view video from a Slingbox?
John
Old 04-25-2010, 11:21 AM
Anyone?
Old 04-26-2010, 07:42 PM
mikejaner's Avatar
I used mine with a Slingox Solo.
Mike Janer
SageTV HD300 Extender X2
Old 04-27-2010, 09:10 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
I'm using my HD-200 with a Slingbox Pro. It's so I can view Sage on my IPOD touch or HTC Touch Pro 2 phone. It also works better in a mobile environment, because Slingplayer tolerates the momentary dropouts in your Internet connection while you are moving.
Server: Home-built i3-4170 3.7GHZ, 500GB SSD, 8GB DDR3, Win 10 64-bit, 4TB of drives for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS211 4TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 07-07-2010, 08:46 PM
PeteCress's Avatar
SlingBox w/HD200?
Anybody doing it?
* merged *
Server: SageTV 7, Windows 7, Intel i7 @3.5GHz, 8 GB RAM, 80-gig SSD drive
Clients: HD200*4 over Cat5e Ethernet + Asus Zen running Client over WiFi-ac + 1 HD200 remote at another residence
Storage: NetGear Ultra-6 NAS 10 TB total w/dual redundancy. Plus (3) 2-tb local drives for RecordedTV.
Program Source: OTA antenna
Old 07-08-2010, 07:49 AM
Doing what? Maybe you should elaborate on what you are actually asking.... or better yet do a search for slingbox and find out your answers....
Old 07-08-2010, 08:18 AM
PeteCress's Avatar
Originally Posted by paulbeers View Post
Doing what? Maybe you should elaborate on what you are actually asking.....
I thought it was self-explainatory: Using a SlingBox to deliver output from an HD200 over an Internet connection.
...or better yet do a search for slingbox and find out your answers....
Mea Culpa on that one: http://tinyurl.com/28d99mt
Sounds to me like it works.
It would also seem to bear on the many comments by SageTV users (myself included) to the effect that SageTV needs to develop an iPhone client.
If SlingBox/HD 200 work as I imagine/hope, the SlingBox client on an iTouch would deliver what I'm looking for - which is live TV. OTOH, I have no clue how the UI is handled over SlingBox... but just based on the assumption that live TV is available and channel switching is possible I think I'm going to give it a try.
Old 07-08-2010, 08:23 AM
Originally Posted by PeteCress View Post
I thought it was self-explainatory: Using a SlingBox to deliver output from an HD200.
Why? That's what placeshifter is for.
The way I understand it, it provides an on screen remote and records whatever the connected box outputs. So you navigate a UI like your there, but with the encoding and transmitting lag.
Old 07-08-2010, 08:36 AM
PeteCress's Avatar
iPhone/iPad/iTouch
Old 07-08-2010, 08:38 AM
PeteCress's Avatar
I'm reading the specs for Solo vs HD and can't figure out whether the solo just does not process anything that is broadcast in HD or it processes HD shows but renders them in something less than HD.
Bottom line: if a show is broadcast in HD, can your SlingBox Solo render it to your handheld device?
Old 07-08-2010, 09:02 AM
mikejaner's Avatar
The answer is yes. The difference between the Solo and the HD is the HD can encode HD. The solo will take an HD input and downscale it to 720x480. For the iPhone this doesn't matter since the screen can't render HD. [Edit: By render I mean Display. Technically, it can render both 720P and 1080i, but the display resolution is 240P (320x240)]
Mike Janer
Old 07-08-2010, 09:15 AM
mikejaner's Avatar
Though I agree with you in principle, I have to say the Slingbox eliminates the codec issue. I can't playback some of the TV I record via HDPVR because the Placeshifter finds a way to play it too slow, or just outright refuse. This doesn't even account for Music/Video/Internet issues with SageTV over Placeshifter.
Considering the delay/lag involved with the placeshifter, the Slingbox connected to an extender is actually a little better, or the same for the experience
Mike Janer
Old 07-08-2010, 10:43 AM
Also, the SlingBox introduces the availability of DVD/BluRay rips you wouldn't get with PS. Is the remote now bundled in the software? I do have some bin files I received from Sling once upon a time for the HD100/200 remote and the MVP but haven't been able to use my SlingBox because of poor DSL service.
B
Old 07-08-2010, 01:25 PM
tbone01 tbone01 is offline
I also use a Slingbox Pro to view SageTV through an HD200 over an iPhone, it does work with one exception- which is sound for Blu Ray rips. My setup is that I use HDMI for the BitStream Audio out for the HD-200 this allows for the 5.1 DTS Audio to travel to my receiver, since the Slingbox is using analog connections, there is no sound for Blu-Ray movies when connected like this. It will produce sound for all of the other formats and files I use.
dish network, slingbox
Interesting article on Slingbox sleonard General Discussion 2 12-25-2008 05:52 AM
Sage and Slingbox-deadly! mohanman SageTV Placeshifter 9 08-01-2008 10:44 AM
Can a Slingbox control an MVP? FZ1 SageTV Media Extender 13 04-07-2008 05:05 AM
Slingbox Personal Broadcaster spike5884 General Discussion 9 02-20-2007 04:19 PM
Slingbox and SageTV brando06 General Discussion 0 01-24-2007 01:15 PM
