Old 04-17-2019, 06:12 PM
gclayto's Avatar
gclayto gclayto is offline
Docker startup error.
I have been running docker on a Synology without incident except for the occasional need to restart. Today, I restarted the docker, it will run for about a minute and go into a boot loop. It refers to disk quota but there is plenty of space on the drives. Any ideas on what is causing this issue?
Log file is attached.
Old 04-23-2019, 07:11 AM
Normally the /opt/sagetv/ folder is mounted to your NAS filesystem external to the docker container (as is /var/media). So, if this is mapped correctly, then it may be that the share to which you mapped this has run out of space? If it's not mapped, then, it means all that stuff is being put into the container and is not persisted anywhere, but the container might be out of virtual space.
Unraid 6.3.1 Docker Update Error dgeezer SageTV for unRAID/Docker 3 02-16-2017 10:17 AM
Startup Error geekout2 General Discussion 4 02-13-2007 01:35 PM
Error on startup videogeek SageTV Recorder Software 3 07-12-2004 03:38 PM
Client error on startup ry12a SageTV Beta Test Software 4 02-02-2004 05:40 AM
Java null pointer error on startup Bear SageTV Software 11 01-26-2004 05:32 AM
