Old 09-01-2008, 05:05 PM
shadeblue.com's Avatar
shadeblue.com shadeblue.com is offline
Arrow STV Import: Dead Pixel Test
To assist in visually inspecting a LCD TV for dead or frozen pixels, it is helpful to flood the screen with solid colors to help identify certain defect pixels. In the past I have always connected a laptop and used the free "Dead Pixel Buddy" utility program; however, I thought this functionality would be useful directly embedded in my SageTV. So, here is a STVi import that creates a "Dead Pixel Test" menu item in the main Setup menu for the Default STV.
This import allows the user to flood the screen with the following colors: Black, White, Red, Green,Blue and Yellow.
- Default STV -
- SageMC -
After selecting a color, the entire screen will be flooded with the selected color. To exit this screen, select the BACK button on the remote. (or CTRL + Left Arrow on a PC keyboard)
Please note, if you are using nielm's dynamic menu STVi, then you will need to manually create a new menu item that links to a "New Internal Screen" named: "PixelTest"
SageMC Users:
To add the PixelTest pages to your menu, you can use the Nielm dynamic menu and manually create a new menu item that links to a "New Internal Screen" named: "PixelTest" or you can add the following properties to your Sage.properties or SageClient.properties file to get this import to show up under the "My Plugins" page.
sagemc/plugins/DeadPixelTest/Title=Dead Pixel Test
sagemc/plugins/DeadPixelTest/Author=shadeBlue.com
sagemc/plugins/DeadPixelTest/Menu=PixelTest
More Information is located on the DOWNLOADS page
Old 09-01-2008, 05:08 PM
This is my first STVi, so be kind
Old 09-06-2008, 02:22 PM
RELEASE 1.0.1
New Release v1.0.1 is now available.
- support added for SageMC
- add LEFT arrow to exit fill pages (same as BACK)
Old 06-13-2010, 06:06 PM
Pixel Test V7
This plugin has been updated to work in SageTV Version 7.0.
This plugin is available in the list of "Available Plugins" under the "UI Mod" category in the SageTV 7 Plugin Manager.
Setup Navigation Link:
Pixel Test Menu:
Server Hardware: Intel Core 2 Quad Q6700 2.66GHz CPU, 4GB DDR2 RAM, NVIDIA nForce 780i SLI Motherboard, GeForce 8600 GT, Seagate Barracuda 7200.11 2.5TB
Operating System: Windows XP Professional
HTPC/DVR Software: SageTV 7
Capture Devices: 2 @ Hauppauge HD-PVR (1212), Hauppauge WinTV-HVR-1600 ATSC/QAM, HD Homerun
Media Extenders: 2 @ Sage HD100 & 1 @ Sage HD200
Signals/Providers: AT&T UVerse, OTA ATSC
Set-Top-Box: 2 @ Motorola Box VIP 1200
Simple (but effective) security for any STV Lester Jacobs SageTV Customizations 5 12-17-2010 03:21 PM
STV Import: SageMC MovieTimes Movie Listings v0.64 Morgan111 SageMC Custom Interface 419 10-01-2010 11:06 PM
SageTV and import folders bastafidli SageTV Software 0 01-27-2008 12:42 AM
STV Import request: Exit SageTV korben_dallas SageTV Customizations 1 08-11-2006 07:24 PM
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) Cayars SageTV Customizations 3664 12-13-2005 05:35 PM
