Old 05-30-2020, 10:24 AM
BigSwifty's Avatar
BigSwifty BigSwifty is offline
Spinning arrows & freezing videos
Please see my sig for system details.
All of the described behaviors occur only on the Server/Client machine. Client 2 is working fine.
I have been having very frequent recording and video playback freezing leading to spinning arrows. The majority of time, this requires a 3 finger salute to end the task. There are frequent spinning arrows with any remote command to change menus.
All recording drives on the NAS machine and on the server/client machine are without any SMART errors/warnings.
From the suggestions found on the forums, I considered a network issue. I tried a new network cable, new switches, and put a new network card in the server/client... the issue remains.
I tried to select “DEBUG” for Gemstone but it doesn’t seem to be sticking and is logging “INFO”. I attach recent logs. Looking for any and all help please.
SERVER/CLIENT_1--> AMD Phenom2 X4 925 2.8GHz. 8Gig mem. Asus M5A97. // Win 7 x64 // GTX 1060. //Ceton infinity 4 Comcast // SageV9.2.2 x64 running Gemstone // Lots of HD space. Recording to a NAS
CLIENT_2--> AMD Athlon 64 X2 5400 Brisbane 2.8GHz. 4Gig mem. GIGABYTE GA-MA780G-UD3H// ATI 5570. // Win 7 x64
Old 05-31-2020, 12:50 AM
tvmaster2's Avatar
Seeing the same thing for the last month. Checked all the same things as you, but I don’t use Gemstone. Can’t seem to fix it. Two tuners by Hauuppaug
Old 05-31-2020, 04:06 AM
The 2 times I've experienced this...
1. network issue
2. hard drives were spinning down
#2 one fooled me for a bit, because it was erratic, but, because my NAS was spreading files across multiple drives and those drives were set to spin down, then, when sagetv would access a fanart image, etc, it would have to wait for the drive to spin up resulting in the spinning circle.
I've never seen it in a video, only when playback is done and I'm trying to get back to a menu.
Old 05-31-2020, 07:45 AM
BigSwifty's Avatar
Thanks for the replies. I forgot to add that all the HDs are set to not spin down.
Frustrating.
Old 05-31-2020, 09:11 AM
tvmaster2's Avatar
Frustrating.
Good idea - where does one check in Windows for whether your drives are set to spin down or not? I haven’t made any changes, but it’s always possible an update has?
Old 05-31-2020, 09:12 AM
tvmaster2's Avatar
1. network issue
I see it when doing both switching live channels, and triggering a recording.
Old 05-31-2020, 09:24 AM
BigSwifty's Avatar
Power options -> "CHANGE PLAN SETTINGS" advanced. Hard disk options.
Old 05-31-2020, 10:48 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
Where is this? A search for "Power Options" takes me to "Power & sleep setting" -- no Advanced option there. A search for "Change Plan Setting" give me "No results." (This is searching in "Windows Setting" from the Start menu in Windows 10.)
Old 05-31-2020, 12:01 PM
tvmaster2's Avatar
Thanks. Ok, all good there. I thought there may have been a hidden Sage setting I didn’t know about. Guess I’ll start network testing...
Old 05-31-2020, 12:05 PM
tvmaster2's Avatar
In W10, start the search with ‘Edit Power Plan’, then ‘Change advanced power settings’
Old 05-31-2020, 12:47 PM
graywolf's Avatar
graywolf graywolf is offline
One thing I’ve found is get it a lot when adding padding to manual recordings
Noticed when getting clocking that the SageTV is using 75+ CPU %
Old 05-31-2020, 02:00 PM
RonBoyd's Avatar
Okay, I am a little dense. I have the hard drive set to turn off after 20 minutes. Is that what you refer to as "spin down"? See image.
Old 05-31-2020, 02:18 PM
KryptoNyte's Avatar
That's correct, Ron. If you take that down to zero or beyond I believe it will say 'never' which is what you want.
Old 05-31-2020, 03:44 PM
BigSwifty's Avatar
Hopefully not premature, but my issue might be resolved.
My NAS is actually a repurposed Win7 machine whose only purpose is a file server running snapraid. All recordings, music and movies are stored there. I didn't change it's network adapter since the other Sage client didn't have any issues and I didn't think it was the problem
I changed the adapter on the file-server machine (naturally the last part of the network that I didn't troubleshoot) and the Sage server/client machine seems well at this time. Weird that it only affected that machine and not the other client.
Holding my breath.
Old 06-01-2020, 10:42 AM
graywolf's Avatar
Holding my breath.
What did you change?
Old 06-01-2020, 12:02 PM
BigSwifty's Avatar
I sequentially changed everything. Started with new network cables between the machines and the switches. No joy.
Bough a new network card for the Sage server/client. No joy.
Swapped out both switches with known good switches. No joy.
Finally took previously mentioned new network card and put it in the "file server"
Old 06-01-2020, 08:09 PM
BigSwifty's Avatar
Seems to be fixed! Have not any spinning/freezing since changing the network card in my file server machine.
spinning wheel sflamm SageMC Custom Interface 9 08-10-2011 11:25 AM
"Videos by Folder" View FREEZING on 1 HD200 Stach SageTV Beta Test Software 1 09-16-2010 12:17 PM
Video speeds, slows, controls and arrows vanish david zero SageTV Software 0 10-23-2008 10:32 PM
6.3.5 OSD & Direction Arrows Polypro SageTV Customizations 3 12-31-2007 09:12 AM
channels arrows talonmike SageTV Beta Test Software 2 08-08-2007 09:40 PM
