Old 10-19-2006, 12:58 PM
00sage00 00sage00 is offline
SAT please help
I had Sage working perfectly at my old apt with cable. Now I moved to a new place and all I could get was Direct Satellite is there a way to get the SAGE box to work with SAT? If so what adjustments do I need to make. Will the box be able to change channels ect? I found my SAT company in the listing and it gives me the appropriate tv guide but the screen is blank. I cannot the same cable to a tv from the reciever and the TV works fine. As soon as I plug that same cable into the SAGE box there is nothing.
Help!!!
Old 10-19-2006, 01:46 PM
Polypro Polypro is offline
I don't run any sat or cable boxes, but I believe you would connect one box per tuner, via S-Video and then go through the Sage Setup and tell it you're using external boxes. You will need IR blasters for channel changes.
P
Old 10-19-2006, 03:02 PM
sennbj's Avatar
sennbj sennbj is offline
Help!!!
I have my SD capture card (PVR250) hooked up to a Direct TV Sat box. I use the composite in on the PVR250 and a USBUirt IR "blaster" to change the channel on the SAT box as needed. It works great and all is good.
SERVER
AMD 1800, 512 MB Ram, 480GB, XP Pro, Sage 5.0.2.90, Geforce2MX, PVR 250, FusionHDTV5 RT Lite, USB UIRT to Direct TV reciever
CLIENT
AMD 64 3500, 512 MB Ram, XP Pro, ATI X300 Onboard Video, nVidia PureVideo Decoder, SPDIF Optical Out to Kenwood DTS
Old 10-19-2006, 03:18 PM
MoopZilla's Avatar
MoopZilla MoopZilla is offline
Depending on the model of satellite box you have, you may be able to use serial control to change channels.
Server: Antec NSK2400 Case, Intel Core 2 Duo e8500, 2GB DDR2 RAM, XP SP3, Gigabyte Fanless 7600GS PCIe 256MB, Sage v6.4
Tuners: 1 H21-100, 1 H20-600 on HD-PVRs both using Serial port tuning(DirecTV), HDHomerun on Comcast ClearQAM
Storage: Seagate 500GB SATA2, WD 1TB SATA2
Video/Audio: Overlay and Cyberlink video/audio
Clients: 2 STX-HD100 HD Media Extenders, 1 MediaMVP
Old 10-19-2006, 04:03 PM
blade blade is offline
Also you can't use both tuners in a dual tuner sat boxes with Sage because one is controlled by RF instead of IR and there isn't an RF blaster for Sage. So you'll actually need one sat box for each capture device you intend to use. I don't know if you plan to use more than one capture device, but I thought it was worth mentioning since I've seen people make the mistake before.
