Old 01-25-2008, 06:53 PM
TechBill's Avatar
TechBill TechBill is offline
Channel lineup not downloading or SageTV not clearing channel lineup when I remove it
I removed a tuner source but Channel Guide showing all channel still there with blank guide on it so I am thinking a bug and readd the tuner source and then select the same channel line up but it stay at "Please wait while the channel lineup is downloaded"
If I cancel it it just still show blank channel guide still.
Any idea how to corrrect it?
Bill
HTPC System
Media Extenders
HD300
HTPC Software
Old 01-25-2008, 10:14 PM
If no sources are using the lineup, it may just need to go through an EPG update to remove the unused channels/lineups.
Old 01-26-2008, 12:51 AM
TechBill's Avatar
I just restarted service several time and it finally disappeared from channel guide.
Bill
HTPC System
Media Extenders
HD300
HTPC Software
Is there a way to select which tuner to set the channel listing by? TechBill SageTV EPG Service 0 12-24-2007 09:27 PM
Using the DVB EPG to control a STB Doubletop SageTV EPG Service 11 11-06-2007 09:00 AM
StephaneM's XMLTV importer Question gerberdude SageTV EPG Service 11 07-31-2006 06:50 PM
Subscription Options ? LCH SageTV EPG Service 72 07-09-2003 05:38 AM
