Old 04-06-2008, 06:01 AM
ranageman ranageman is offline
DVB subtitles: what is the situation?
I have a Hauppauge Nova-T USB2 receiver (if that is important): I have set cc_option_enabled=true and I can choose between CC Off, CC1 and CC2 on live broadcasts.
However, no subtitles appear where I would expect them, e.g. during news broadcasts where a foreigner is being interviewed.
I have tried running mpg2srt on the recorded video - no information extracted. Nor does WinDVD display any subtitles when it plays the video file. I note that closed caption support is not official right now, but exactly how this relates to DVB subtitling I am not clear on.
Can I get Sage to display these subtitles?
/RM
Old 04-06-2008, 08:47 AM
jerryt jerryt is offline
For normal Closed captions to work you need cc_otion-enabled=true, intervideo (or similar), CC1 selected and VMR9 selected.
But for CC in DVB, Try the modified FFDshow codec posted on DVBN. Working well in NA.
Old 04-07-2008, 01:33 PM
Clarification?
So, if I read correctly: DVB subtitles are NOT supported - only closed caption which is something different (U.S. and Canada only?).
How will a different codec help, if the subtitles are not being embedded in the recorded stream (according to mpg2srt) ?
/RM
Old 04-07-2008, 02:14 PM
Nothing can help if the subtitles are not embeded.
There are sites which can supply a subtitle file for movie which don't have subtitles, but I have never used that method.
Old 04-07-2008, 02:59 PM
ke6guj ke6guj is offline
/RM
YOu may want to try ccextractor on those recordings to see if there is any digital captions embeddeded. Syntax would be ccextractorwin.exe -srt recording.mpg. That would create an .srt file that you can open in notepad and see if there is captioning that maybe a different decoder could display.
edit: YOu may want to follow this thread for more info on DVB subtitling, http://forums.sagetv.com/forums/show...light=teletext
- Jack
Sky via DVB S cards directly - any advice? johnw SageTV United Kingdom 21 05-09-2008 09:30 AM
DVD to DIVX with subtitles mrcandu General Discussion 2 01-17-2008 07:07 AM
Dragging/skipping video while using subtitles kimarachan SageTV Software 0 01-10-2007 10:59 AM
DivX Subtitles Belgrath SageTV Software 0 09-29-2006 02:04 PM
Diabolical Subtitles DwarF SageTV Software 3 03-26-2006 09:04 AM
