Old 01-28-2009, 10:32 PM
mijahauan mijahauan is offline
TME works but SageTV gets "no signal" with HDPVR
Using:
HDPVR -- 1.053 drivers
TME installed from Hauppauge cd and then upgraded
SageTV 6.5.6
So the TME programs work fine -- playback, record, etc.
SageTV, however, simply gets "no signal". Using the program guide, it does instruct the HDPVR to send IR signals to the DirectTV to change the channel. But no audio or video signal when attempting to watch live TV or record.
Any ideas?
mjh
Old 01-28-2009, 10:48 PM
I should add that I just blew away SageTV 6.5.6 and installed 6.5.8 from scratch. During setup, it recognizes the HD PVR but never loads a preview...
I've re-installed the HD PVR drivers several times. Again, the ArcSoft TME receives audio and video just fine...
mjh
Old 01-29-2009, 12:23 AM
So I poked around a bit and found one poster, smdl, got a similar problem fixed by removing *everything* and re-installing one, by one. So I did that, too, including running hwclear.
I rebooted.
New hardware recognized.
Windows found the Hauppage cd and automatically loaded the drivers.
I installed the default software from the same cd -- irblaster stuff and ArcSoft stuff.
It all worked.
I upgraded the HD PVR driver to 1.053 and rebooted.
Everything still worked.
I installed SageTV 6.5.8 and marched through the setup selecting mostly default stuff.
It found the HD PVR as a video source and, (contra above) *did* show a video preview (with sound) first time through. I briefly thought, "hurray!!".
But then, on getting to the "Configure Video Playback" configuration, none of the settings worked -- neither Basic, Medium, Standard, or Advanced. I clicked through anyway and under "Detailed Setup" set the video decoder to "ArcSoft" and the audio decoder to "ArcSoft".
No Signal
Can't find any combo of settings that gets anything other than
No Signal
I'm at a loss.
Went back to TME and video and audio continue to work fine.
mjh
Old 01-29-2009, 12:27 PM
mayamaniac's Avatar
Contact tech support: support@sagetv.com
Also, I would try deleting the whole SageTV folder before reinstalling.
Mayamaniac
Old 01-30-2009, 06:29 PM
ghostlobster's Avatar
ghostlobster ghostlobster is offline
Send a message via MSN to ghostlobster
Are you using SPDIF for audio or component? I get No Signal with SPDIF but it works with component.
Ghostlobster
Server: Athlon 3000+, 1GB RAM, 2 Hauppauge 150s, HDHomeRun, HD-PVR driving 3 clients.
Client 1 - Athlon 4600 x2, 2 GB RAM, ATI HD2600 XT
Client 2 - Athlon 4200 x2, 1 GB RAM, ATI HD2400 Pro
Client 3 - Athlon 4200 x2, 1 GB RAM, nVidia 8500 GT
Raleigh Computer Repair
Old 02-09-2009, 09:38 AM
pvrnorth pvrnorth is offline
mjh,
Did you solve your problem? I get No Signal as well with my HD-PVR if I have a channel changer configured. If I have nothing configured to change channels it works great... other than me having to manually change the channels
"no signal", hdpvr, tme
Firewire recording + HDPVR on one cable box Endymion Hardware Support 1 04-01-2009 02:15 PM
Live Studdering/slow video after channel change with HDPVR hvymetal SageTV Beta Test Software 14 12-25-2008 02:51 AM
Setting up a 2nd HDPVR dislecksea Hardware Support 5 12-12-2008 10:10 PM
"No Signal" Error for Live TV at show end shaggykevv SageTV Customizations 4 10-26-2008 05:38 AM
Anyone have any luck with HDPVR? rick s Hardware Support 6 09-12-2008 08:00 AM
