Old 02-23-2009, 06:10 PM
rbarr110 rbarr110 is offline
Upgrade question
I am still in the process of deciding to upgrade or not, but am confused by the upgrade option
On the ordering page it says:
This product is an upgrade only and requires full version of SageTV Version 4 or earlier. To purchase the full version of SageTV V6 click here.
If I purchase the upgrade, does this option require that I install over my old version 4 software, or can I do a full/clean install of version 6.5?
Old 02-23-2009, 06:17 PM
robogeek robogeek is offline
You don't have to install over the old version. If you install over the old version, when you register it on the computer, you will only need to enter the new upgrade serial number. If you do a full clean install on a new machine or on a fresh installation of the operating system, you will need your old serial number and the upgrade serial number you get when you purchase the upgrade. So, with a fresh installation, you'll have to enter your old serial number first and then the new serial number to activate the new version.
--Jason
Server Hardware: GIGABYTE GA-EP45-UD3R, Intel Q9550 CPU 2.83GHz, 11GB RAM, 1xHDHR, 1xHVR1600, 1xHVR2250
29TB Server Storage: 1TB SSD (OS), 1TB (data), 2x6TB+2x10TB (22TB FlexRaid storage pool), 2x2TB (recordings), 1x750GB (VMs).
Server Software: Win10 Pro x64 OS, SageTV 64bit v9.2.0.441, Java 1.8 u241, PlayOn, Comskip (Donator) v0.82.003, WampServer v2.5.
Clients: 3xHD300s, 2xHD100, 2xPlaceshifters
Old 02-23-2009, 06:39 PM
Thanks for the info!
Hardware Upgrade question VikingCrown Hardware Support 2 02-25-2008 08:01 AM
Upgrade from 5x to 6x question tvmaster2 SageTV Software 1 12-20-2007 02:42 PM
To upgrade or not to upgrade - That is the question.... scoful SageTV Software 3 05-31-2007 05:35 AM
Upgrade Question jphhughes Hardware Support 8 04-06-2007 09:09 PM
4.0 to 4.1.3 Upgrade Question mightyt SageTV Software 10 12-17-2005 03:54 PM
