Old 03-29-2009, 08:43 AM
bfb1963 bfb1963 is offline
Is ArcSoft TME required for headless WHS server?
I run HD-100s exclusively off my WHS server, and am trying to add HD-PVRs to the server. Can I just install the updated Hauppage drivers for the HD-PVR without the ArcSoft TME software? I can't find the supplied install CD with ArcSoft TME on it.
thx.
Old 03-29-2009, 09:05 AM
That's what I did, just the Hauppauge Drivers (though my server is Server 2003).
Old 03-29-2009, 10:31 AM
PLUCKYHD PLUCKYHD is offline
Yes you are correct if you don't intend to setup the tv signal or view it on the WHS you don't need tme.
Old 03-29-2009, 05:27 PM
I do plan to use the HD-PVR to capture from my STB. Is that what you mean by "setup the TV signal"?
Old 03-29-2009, 06:33 PM
Yes since you won't be able to decode without the tme software on the server set your signal up on a extender/client
Old 03-29-2009, 08:14 PM
If that is so, then what is stanger89 doing without it?
Old 03-30-2009, 04:52 AM
thx.
The answer is yes. Unless you are also trying to view video on WHS. (Which I would recommend against. WHS is a headless server solution to be used as your backend media server) Changes to the audio input (analog or SPDIFfor the HD-PVR) can be made with Sage.
Old 03-30-2009, 07:59 AM
You DO NOT need Arcsoft TME on the headless server. The HD-PVR sends an encoded signal to the server and Sage simply(not really) writes it to a file. The only purpose for the Arcsoft TME software is to decode that file. It's only needed on the client.
-B
Old 03-30-2009, 08:25 AM
I was simply impling not to set up the tv signal from the whs computer but from a client/extender. Because you won't be able to view the feed during setup directly on the whs.
Old 03-30-2009, 09:08 AM
Ok. That's what i thought. Unfortunately sagetv crashes when i install the Hdpvr. That will probably be another thread.
THX all!
Headless Server: Worth A UPS? PeteCress Hardware Support 52 03-06-2009 03:38 PM
Question on WHS and SageTV Media Server V6.5 for WHS Texas-Hansen SageTV Software 8 02-10-2009 07:55 PM
What OS for headless server? sunlover General Discussion 68 02-05-2009 06:15 PM
Headless Linux Sage server schmots SageTV Linux 2 09-20-2007 10:39 AM
Moving to a headless server - help! bialio SageTV Software 2 07-18-2007 01:20 PM
