Old 05-16-2009, 09:47 AM
Shag Shag is offline
Subtitles support
I got the latest beta firmware (20090505), and I can get subtitles to work with DVD and mkv files, but they don't work with DivX or mp4 (.sub, .srt). For those files, I can usually (but not always) select the subtitles options in the options menu, but nothing appears on the TV. Am I missing something?
Is this not supported?
Old 05-16-2009, 10:15 AM
Lucas Lucas is offline
They are supported. I don't have such issues. There's probably something wrong with your srt files. Submit a bug report for sagetv to have a look at your issue.
3 x HD300s
Old 05-16-2009, 11:20 AM
Ah I'm bummed. It doesn't work.
I'll submit a support request.
I got the beta firmware, and in the system details it says software version Sage TV 6.5.14.1, and current STV file 6.5.15.3. Is this correct?
You didn't have to toggle any other options or do any other modifications to get them working?
Old 05-16-2009, 11:37 AM
Oh, and I'm using the HD200 in standalone mode, watching movies over ethernet.
Old 05-16-2009, 11:02 PM
In that case, file a bug report. My comments above where for extender mode.
3 x HD300s
Old 05-18-2009, 08:48 PM
Did anyone manage to get subtitles working for separate .srt and .sub files for DivX movies when using the HD200 in standalone mode with the latest firmware? (20090505)
Old 05-20-2009, 05:55 PM
Stuntman's Avatar
Stuntman Stuntman is offline
subtitles timing?
I have an issue where after a commercial skip (comksip) the subtitles get out of sync.. I'm using ccextractor to get them out so that I can use them on my MVP.. anybody else seeing this.. does anybody else use the MVP any more?
Intel Q6600 Quad Core, 8GB RAM on Windows 7 Professional x64
Subtitles support and the HD-100? rtengvad SageTV Beta Test Software 4 03-24-2009 10:58 PM
Subtitles for TV bunch92 SageTV United Kingdom 4 02-18-2009 05:48 PM
Support for DVB-C subtitles and teletext PAL when? chrik SageTV Software 6 05-29-2008 02:45 AM
subtitles vorius SageTV Software 1 01-20-2008 01:20 PM
Subtitles??? Iggy SageTV Software 0 03-18-2006 03:03 PM
