Old 06-11-2009, 02:38 PM
bthurber bthurber is offline
ARCSoft/Hauppauge Total Media Theatre no longer works after Vista SP2 is installed
I've found that the ArcSoft Total Media Theatre client doesn't work now that Vista SP2 is installed. Windows says "This program has known compatiblity issues". ArcSoft says an update is available to fix it, but since I have the version from Hauppauge for the HD PVR, Hauppauge must release the update.
Thankfully the codecs still work since Sage is running ok, but I can't play any Blu-Ray discs because these require TotalMedia client to load.
I'll send a message to Hauppauge support, but I thought I would also post here in case someone else has a similar configuration
Follow-up: This is the reply I received from Hauppauge:
There is currently a known issue with this and a fix is being worked on there is not currently an ETA on it at this point.
Old 08-26-2009, 10:25 AM
Evil_Attorney's Avatar
Evil_Attorney Evil_Attorney is offline
I just performed a reinstall and wanted to confirm that hardware acceleration is turned on in the arcsoft decoder. Previously, I performed this in TMT. Is there another way to edit this setting, such as with filter manager?
Old 08-27-2009, 10:18 AM
MitchSchaft MitchSchaft is offline
Vista SP2 antplugger SageTV Software 2 05-31-2009 04:11 PM
Problem with ArcSoft Total Media Theater cenk SageTV Software 1 02-19-2009 01:37 AM
Using Arcsoft Total Media Theater with SageTV cybrsage SageTV Customizations 2 08-20-2008 07:35 AM
PowerDVD and Arcsoft Media Theatre Integration honeybrain SageTV Software 2 02-09-2008 10:25 AM
Installed SageTV 4 and Xcard no longer works dbfresh23 Hardware Support 6 11-02-2005 09:46 PM
