Old 07-18-2009, 08:40 AM
jc8367 jc8367 is offline
HD-PVR works in Arcsoft but not in Sagetv
I have it configure properly as component but all I get is snow, any thoughts?
Old 07-19-2009, 06:38 PM
Do you have it connected to the component in or the component out?
Old 07-19-2009, 07:01 PM
Update
I am able to get HD channels in Arcsoft and SageTV but none of my normal digital channels appear. All I get is snow. I'm connected via component.
Old 07-20-2009, 05:48 AM
Are you sure you told SageTV that you are accepting input through the Component in? Also check your SPDIF cable and make sure it's in the audio IN connector.....not realted, but many people hit that problem next .
Old 07-20-2009, 06:35 AM
SWKerr SWKerr is offline
Not clear on what you mean by normal digital channels. Just to be clear here. If the channel on your cable box is an HD channel you can see it but if the channel is an old analog station then you get snow.
Is that correct?
Old 07-20-2009, 07:40 AM
Connect your cable box component out to your TV and verify what you get on your TV when you tune to your "normal digital channels". Your "normal digital channels" may have changed from what you think they should be.
Old 07-20-2009, 08:57 AM
snow from the HDPVR indicates the cable box is sending "snow". The HDPVR, I think, outputs blue screen when no input is selected.
So, using Arcsoft software, notice which channel(s) is "working" and attempt to view the same channel in Sage. No reason that shouldn't work. If you get "snow" again, I suggest not touchign the sage remote (or keybaord) but rather change the channel manually using your STBs remote to a channel you know works. That will at least show you have working video and just need to work on the channel changing.
-Brian
ARCSoft/Hauppauge Total Media Theatre no longer works after Vista SP2 is installed bthurber General Discussion 2 08-27-2009 10:18 AM
Problems with HD-PVR and ArcSoft Ian Hardware Support 4 04-29-2009 08:52 PM
SageTV doesn't see Arcsoft codecs complexx SageTV Software 0 02-03-2009 07:13 AM
HD-PVR Drivers 2.0 Out with Arcsoft upgrade jerryt Hardware Support 42 12-19-2008 10:05 AM
Dual PVR-150s, only one IR blaster works. ;-( SageTV 5.0.... neilbradley Hardware Support 2 05-15-2006 03:16 AM
