Old 07-17-2017, 08:42 PM
WellThen's Avatar
WellThen WellThen is offline
Sage Server Hang 3 days after successful V7->V9 Upgrade on Windows 7
Hi All,
On Friday, I upgraded from V7 to V 9 on Windows 7 64 bit. The upgrade went smoothly. (FWIW, I run sage in a Windows 7 VM on an esxi host.)
This evening (Monday), I found the Sage UI non-responsive from Clients. When I tried to exit Sage on the Server (I'm not running Sage as a Service) it hung on the "Are you sure you want to exit SageTV?" prompt (spinning circle of death).
I found that Task Manager showed that SageTV was using 1GB of RAM (screen clip attached.) After waiting 3-4 minutes (memory usage slowly rising), I tried to kill the Sage process, but could not.
I tried to restart the Windows 7 VM, but after showing the normal Windows restarting messages, the restart just hung. I finally had to reset the VM running the Sage Server.
I grabbed the SageTV_1.txt file after the machine restarted, and am attaching it here (It was huge - I had to split it into 2 zipped files to get under the 750KB limit.) Any thoughts about what might be happening?
File Type: zip sagetv_1_Sage9_Hang_7-17-17 - Part1.zip (195.2 KB, 90 views)
File Type: zip sagetv_1_Sage9_Hang_7-17-17 - Part2.zip (559.5 KB, 89 views)
Old 07-17-2017, 10:07 PM
wnjj wnjj is online now
I think you are running out of heap space:
Mon 7/17 16:20:00.005 [Seeker@1e48d0c] MemStats: Used=611MB Total=805MB Max=805MB
If you upgraded from V7, any change you may have made to the registry in the past for heap size likely isn't there. Your system is using the default 768MB.
Thread about heap on V9 here: https://forums.sagetv.com/forums/showthread.php?t=64043
successful upgrade daminc SageTV Github Development 10 03-08-2016 03:44 PM
Is this Sage Server Hang Normal? lolachampcar SageTV Media Extender 1 12-10-2009 01:02 PM
Time for Server upgrade - best Windows OS? Scriber General Discussion 13 10-03-2009 12:21 PM
Sage TV for Windows Home Server Software, HPMediaSmart Server, and HD homerun tuners c309 SageTV Software 15 08-17-2008 06:03 AM
Successful BTV to Sage Conversion deipert SageTV Software 7 01-19-2008 09:15 PM
