Old 04-17-2017, 03:19 PM
wubdich's Avatar
wubdich wubdich is offline
airing filter / switching from XMLTV to Schedules Direct
Schedules Direct EPG (sdepg) plugin for SageTV 7 documentation is mentioning programm and airing filters. Are these still available in the version integrated in SageTV v9 ?
If yes - is it possible to use a program or airing filter to mark an airing as watched if an airing with same show title and episode title (but different showid) is marked as watched in wiz.bin ?
Explanation: This feature would ease my transition from XMLTV to Schedules Direct a lot by preventing doubled recordings (note: showids generated by XMLTV Importer for SageTV differs from showids in schedules-direct - thats at least my current knowledge)
Old 04-17-2017, 07:13 PM
EnterNoEscape's Avatar
Unfortunately filters are not available. If the XMLTV data you were seeing was actually from the same source as Schedules Direct, you might not have any issue with duplicates anyway. If that's the case, then all I would recommend doing is disabling the SageTV compatibility option since the data you got was likely not partly truncated.
Old 04-17-2017, 10:45 PM
wubdich's Avatar
Unfortunatly that's quite unlikely because XMLTV Importer for SageTV is calculating showid by its own - in my case by hashing the episode title and episode number .
How to Migrate to Schedules Direct? reggie14 SageTV EPG Service 51 10-15-2017 07:34 PM
schedules direct garbled epg pschweig SageTV EPG Service 16 04-17-2017 05:28 PM
Using Schedules Direct in UK jamesdisco SageTV United Kingdom 28 02-06-2017 11:54 AM
XMLTV Import Tool & Schedules Direct for USA? rnewman SageTV EPG Service 5 08-13-2008 06:12 AM
