Old 10-25-2004, 01:41 PM
maxpower2078 maxpower2078 is offline
Question How to stop recording a scheduled program in process
I am liking this program so far and just have a few issues to resolve. One big thing is that I can figure out how to stop recording a scheduled show if it is in the process of recording.
Here are a couple of others too.
Also I setup a few favorites, but there are some individual episodes I would not like to record, but when I try to delete the record job (before it happens) from the upcoming recordings, it just reapears again. ???
Another nice feature that I am sure will come up in a future release is having the ability to have a certain quality for live tv and another default one for recording. I know you can just set the default one for what you want it at for livetv and then just change it for your tv shows when you are setting up the recording.
Is there a place to stick in a default time for padding instead of changing it every time a recording is setup?
Old 10-25-2004, 01:44 PM
you need to set watched for shows you do not want to record
to end viewing a recording use stop
to end a recording, make it a manual recording and then cancel the recording and it will be gone
if you are simply wanting to stop a recording shorter than a show's normal length
use the padding feature or setup a manual timed recording
default padding you can get with a Custom STV
nielm's I believe
