Old 08-11-2010, 09:09 AM
Transcoding Speed in V7
Transcodes appear much slower with V7 compared to V6 but I am not sure if this is my hardware or due to a change in Sage - isn't there a change in the Transcoder in Sage7?
My V6 server is a Core2Duo with a 3 GHz CPU.
My v7 server is single core (or HT) but it runs at 3.6GHz.
The conversion job that I was running is to convert an MPEG-2 file to MPEG-4 Deinterlaced. Doesn't the transcoder use a single thread so shouldn't it be faster on the V7 box where the CPU is 20% faster?
Old 08-11-2010, 09:12 AM
darcilicious's Avatar
I don't transcode a lot but yes, there was an update to the transcoder in version 7.0.13. And yes, it does seem slower on my quad-core than in previous releases. But it also fixes the problem of not properly transcoding HD-PVR files
Old 08-11-2010, 01:37 PM
phelme's Avatar
phelme phelme is offline
No more out of sync audio? Have you verified this on recordings that have previously failed?
Backup: Synology
SageTV version: FINAL
Old 08-11-2010, 01:41 PM
I couldn't produce the a/v out-of-sync issue on my transcodings -- but I only transcode using the widescreen iPhone setting.
Old 08-12-2010, 01:40 AM
phelme's Avatar
Tried a recording tonight with the b15 transcoder, out of sync.
Backup: Synology
Old 08-12-2010, 01:45 AM
Neo's Avatar
Neo Neo is online now
You can't compare the cpus by just looking at the GHz.
I think you have a C2D E8400, right?
And the other one might be a Pentium 4?
According to http://www.cpubenchmark.net/cpu_list.php the C2D is much faster
Intel Pentium 4 3.60GHz 582
Intel Core2 Duo E8400 @ 3.00GHz 2242
The values are some sort of comparable index
One core in the E8400 is roughly twice as fast as the Pentium4
i3-7100T, 8GB, Colossus, HDPVR2-GE+, BGT3620, Antec Fusion Case, Win10 64, SageTV 9.2
Old 08-13-2010, 08:06 AM
You are correct in the CPUs. That makes sense - I wasn't sure exactly what the differences are between a P4 and a C2D but that explains it. Maybe I should think about a different PC for my server as I use transcoding a fair bit, or perhaps I can just use SJQ to use another app to do conversion on another PC on my LAN.
Speed up Sagetv? clintj SageTV Software 3 06-20-2009 10:09 PM
Frame rate for 1080i transcoding at half speed mkanet SageTV Placeshifter 3 07-22-2006 02:30 PM
Serious speed fluctuations EChodun SageTV Placeshifter 2 05-23-2006 08:20 PM
Multiple Speed FF and RW? Stuntman SageTV Software 17 11-15-2005 11:56 AM
