Old 05-01-2011, 05:58 AM
Crunch's Avatar
Crunch Crunch is offline
Question HD300 Network Speed Test Tool?
I found following post and after 4 hours of mucking my wife kicked me out of the house
http://forums.sagetv.com/forums/show...02&postcount=8
Is there some easy tool that checks the speed between my server and HD300?
Could sageTV put some program in the extenders to let us test our connection? Seems a lot of questions come up about how exteners are connecting and a tool would be useful.
Reason is for this question is my post...
http://forums.sagetv.com/forums/showthread.php?t=55446
Old 05-01-2011, 06:47 AM
That's the only tool I'm aware of that will speed test from the extender to the server.
Some people are having issues with their Colossus and recordings. It is not specific to an extender.
Old 05-01-2011, 01:02 PM
cat6man's Avatar
cat6man cat6man is offline
put Wireshark on one of your PCs and log the data specifically going to the IP address assigned to HD300, then you can see the streaming speed for any video you care to watch via hd300.
wireshark has a bit of a learning curve but isn't too tough
Q: dad, when will you stop changing all the electronics?
A: never, so you might as well get used to it.
Old 05-01-2011, 01:26 PM
stevech stevech is offline
PC to PC speed, easy: Qcheck
http://www.ixchariot.com/products/da...ts/qcheck.html
Old 05-03-2011, 03:53 PM
SimeonPilgrim SimeonPilgrim is offline
Crunch is correct that is would be useful to have it baked into the server/extenders/client as built-in-diagnostics, that way people could just "test" the through put to lay that concern to rest.
The process to load iperf at both ends is extra hoops to jump through, and the fact that the extender looses the software each time it's full power cycled is annoying. That and having to telnet in, and actually get some telnet software, etc.
As to the Wireshark idea, that would show current bandwidth used, but not capacity, but it would be also useful to have some over the last n-minutes, you have tried to pull n bps but have only effectively gotten m bps.
Need some help with HD300 and Network Configuration hackzaw SageTV Media Extender 11 01-27-2011 09:14 PM
how to test placeshifter while on home network for internet use? toony SageTV Placeshifter 4 07-06-2010 07:42 PM
Disk speed test Folkboat The SageTV Community 4 05-20-2009 07:06 PM
Gigabit network realistic speed bialio Hardware Support 9 05-07-2008 06:40 PM
Is wMCP really that sensitive to network speed? Franc SageTV Media Extender 0 12-08-2006 05:30 PM
