Old 06-21-2008, 12:47 PM
goatboy22382 goatboy22382 is offline
HD100 and WHS
Maybe I am using the wrong search terms but I haven't found anything. Will the $250 bundle with the HD100 and license allow me to install SageTV WHS edition and watch it on the HD100? Eagerly awaiting an answer so I can place my order.
-Mike
Old 06-21-2008, 01:20 PM
othy othy is offline
-Mike
As I understand it, the SageTV Media Center license is valid on all of the different OS builds. I'm sure someone will correct me if there are exceptions (such as SageTV for Mac?).
Just download the version you want (in your case, the WHS build) and enter your key from the email they send after your purchase. In WHS, you can do it from the SageTV button on the Console. You can also enter your extender license in the same place.
I ran Sage on XP for a long time then built a WHS server. I just downloaded the WHS version and entered the same old key, which it took without complaint.
EDIT TO ADD: You've probably already done your research, but be sure to check the threads on WHS. It works great, but you'll want to keep your recording drives out of the storage pool (and formatted w/64k clusters). OTher than that, setup was pain-free for me.
Tim
Server: WHS, Phenom 9150e Quad-Core, 2.0TB for recordings (pooled). HD-PVR (w/USB-UIRT), HDHR, ATI550.
Clients: HD200 (wired), HD100 (wireless via Netgear WNHDEB111).
Old 06-21-2008, 01:54 PM
That's what I figured but I wanted to double check. While I don't have a tuner right now and will mainly use this for ripped dvds how hard is it to move the recorded content off non shared drives and into the storage pool?
Old 06-21-2008, 02:11 PM
If you don't mind them showing up in your Media Library (and without meta-data) rather than your recordings list, it's simply a question of adding a shared folder (probably Videos) as a Media location in SageTV and then moving your files there.
I don't know of a way to store recordings in the pool and still have them show up in your recorded TV list (without adding the pooled location as a recording drive, of course). Maybe someone will chime in with some help.
Does that make sense? I'm not sure if I'm answering your question.
Tim
Old 06-21-2008, 02:21 PM
That makes sense, Is there a way to move the files with in sage?
Old 06-21-2008, 02:35 PM
You need a different license for the Windows, Mac, and Linux versions of SageTV.
The Windows license version can be used for any Windows install of SageTV, including the WHS version -- there is a separate WHS download on the downloads page.
HD100 Issues: stuttering and OSD othy SageTV Media Extender 4 05-29-2008 08:33 PM
New Tranquil PC WHS with SageTV? calypsocowboy General Discussion 3 03-27-2008 08:29 AM
new SageTV user with HD100 Question jelentz@gmail.c SageMC Custom Interface 8 03-13-2008 01:04 PM
SageTV+HD Media Extender: 1st Impressions jamma SageTV Media Extender 7 12-20-2007 03:49 PM
New setup - WHS R5000 HD100 - No Video mediahome SageTV Software 2 12-15-2007 03:00 AM
