Old 09-13-2010, 05:26 PM
Graygeek Graygeek is offline
HD100 Extender License, is it tied to specific HD100?
Have two HD100's and plan to pull one when my HD300 arrives. Since I have two extenders, I received two licenses from Sage @ purchase time. I see nothing in the license email or anywhere tying a specific license to a specific extender. So, it looks like it is just one license per extender regardless of which extender and as long as I only remove one license, either one, I should be fine with the remaining extender?
Old 09-13-2010, 05:35 PM
Right, extender/placeshifter licenses are "seats" they aren't for specific boxes/placeshifters.
Old 09-13-2010, 05:36 PM
carlgar carlgar is offline
It is not tied to any extender at all. It is just the same as the Placeshifter license. If a Hd100 is off, then another instance of a placeshifter could use it.
Old 09-13-2010, 05:52 PM
Thanks for the quick reply's! Sounds like all I need to do if check my email every 10 seconds looking for that HD300 shipment notice!
Bought hd100 which license do I need? joey3002 SageTV Media Extender 4 03-05-2009 07:56 PM
HD100 Extender will not boot Skybolt SageTV Media Extender 4 10-22-2008 02:03 PM
HD100 - Where is the License? Eckwell SageTV Media Extender 4 03-19-2008 06:15 PM
Alternatives for the HD100 HD Extender? bond00 SageTV Media Extender 3 02-25-2008 08:10 PM
Sagetv server thinks client license is tied to another system??? rdefino SageTV Software 1 08-26-2006 02:54 PM
