Old 02-13-2006, 05:21 PM
c309 c309 is offline
Zone Alarm settings
My media extender wont boot if I have my ZA Firewall settings High(stealth), on internet zone, and High(stealth), on trusted zone. It works fine with both on medium.
Anybody know for sure how to configure custom settings for both and or advanced, so I can keep it on High all the time?
I have Zone Alarm Security Suite--basically ZA Pro
thank you in advanced
tom
Old 02-13-2006, 06:33 PM
You could see about adding the required ports that need to be opened. That might work for the high setting, but I added my entire local network IP range as a trusted zone, then left the trusted zone on medium & internet on high.
Edit: I just updated the ports list for a media extender; a couple ports were removed.
