Old 08-17-2006, 08:53 PM
tankd0g tankd0g is offline
What does placeshifter replace?
I have SageTV 4.1, I just downloaded 5 and it installed ok and retained my registration. Will placeshifter install over SageTV client 4.1 or is it a different product?
Old 08-17-2006, 09:04 PM
The Placeshifter client is a separate product compared to SageTVClient and uses a different license. If you have SageTVClient installed, you want to download & install its update also.
Placeshifter allows you to remotely connect to your SageTV server so you can use the full SageTV interface & play media while away from home.
There are a few discussions on the difference between the Placeshifter client & SageTVClient in this Placeshifter section of the forum.
Old 08-17-2006, 09:18 PM
I see, thanks.
