Old 03-10-2009, 12:00 PM
c309 c309 is offline
connection to sage tv server lost
running client with hd 200 and hp media server(sagetv whs). The hd 200 works ok. But I get endless attempting to restore connectionon my laptop(with client). Both are same software version.
When opening ports on router for client........which ip address do I use(the server where sagetv whs is installed)? That is what I used.
Opened all ports tcp in windows firewall.........
still attempting to restore connection
help plz
Old 03-11-2009, 06:34 AM
Are you able to connect at all? If not, did you setup your Sage Server to work with both PC Clients AND Extenders?
If you are able to connect periodically, how are you connecting to your server? WIFI or Ethernet?
Maybe you need to provide a bit more of your setup so we can further help....
Old 03-11-2009, 07:18 AM
thanks for the reply Paul,
I connect to my server with no problem both wirelessly and wired from anywhere. I am connecting wired to server using sagetv client. The program loads up and says" the connection to the sage tv server has been lost. attempting to restore the connection..."
remote desktop on server works fine from the same computer and after running config wizard the client is enabled as is extender and placeshifter.
Placeshifter works fine on same and all computers.
But no client........
client is the same installation as on server 6.5.11 whs, and client 6.5.11
HD200 works perfectly with HDHR....and the server I'm using is a hp media smart
thanks again for any help
Wireless connection from Sage Server to HD Extender paintedbird SageTV Media Extender 12 12-29-2008 12:40 AM
Lost server connection stops DVD sleonard SageTV Software 5 07-24-2006 09:56 PM
Connection to server lost when server busy Dekard SageTV Linux 2 04-20-2006 06:43 AM
The Connection to the SageTV Server has been Lost dvd_maniac SageTV Software 2 10-18-2005 04:40 AM
attempting to restore connection to Sage server? salsbst SageTV Beta Test Software 4 02-29-2004 06:18 PM
