Would it be possible to add CLI switches to Sage?
![]() I'd like to be able to launch Sage directly to Live TV (not the interface/menu) pretuned to a particular channel. |
There no longer is any formal development, though you might want to post your question in either the github or V9 customization forums. Any support or enhancements would be done by another user in their spare time.
BTW, welcome to SageTV. ![]() |
k
If you wish to see what I am up to and support my efforts visit my Patreon page |
There's already some CLI capability. Have a look at the Sage TV User's Guide (pdf), Appendix D, "SageTV Command Line Parameters". It'll take a bit of work on your part to translate the channel # digits to Sage's "event #", but it seems doable.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
Yes, this would be a simple plug in to write. I'm not really interested in making a "formal" plugin but would be willing to make a "one off" for you.
Another way to do this could be to send keystrokes from a programmable remote like a Harmony after waiting 30 seconds or so for the extender to turn on, assuming an extender. Or send keystrokes to a PC if using a PC.
EventGhost is another option that would allow sending of keystrokes based on the program start. The program already has a dedicated SageTV pluging that would allow you to send direct commands to Sage.
What is your client for this instance of SageTV? An extender? A PC running the full server edition of SageTV? An AndroidTV box?
You could probably use curl from the CLI to do what you are looking for via the SageTV API or hit to the Sage Web client. That may require knowledge of the MAC or IP address of the client/miniclient.
TIA ![]() |
Is there a shortcut key combo to do this from the Main Menu? |
The shortcut says "Server Edition" but I don't know if it is the "Full" version or not. ![]() |
It sure seems like the SendMessage utility could do what you're looking for. It's described in Appendix J in the manual. It essentially pushes the same buttons a user would to navigate (i.e. HOME, DOWN, SELECT, etc.). If you use the same sequence starting with HOME, it should be repeatable.
Anything that isn't not a miniclient (i.e. extender or Android) is "full".
![]() Quite by accident, I discovered if you simply hit the left arrow, it switches to LiveTV (the "long" way is PgUp... in case you were last on another menu... Right, Down, [Enter].) ![]() Now, how do I decipher how to use the cryptic "SendMessage" command? I created a bat file to call "SendMessage.exe" with switches, but it wants a Class name, a windowname, a "Message" and parameters. ![]() |
Appendix J: Using the SendMessage Utility When SageTV is installed, SendMessage.exe (version 2.2) is also placed in your SageTV directory. If that file is not in your SageTV directory it may be downloaded from the attachment to this forum post: http://forums.sagetv.com/forums/showthread.php?p=125680&postcount=1 This utility was created by a SageTV user and is provided by SageTV “as-is”. Use of this utility is not supported by SageTV’s technical support. If you need help using this utility, please go to our discussion forum at forums.sagetv.com/forums. The SendMessage utility can be used to send commands to SageTV as Windows messages, using the command event numbers. See: Sending Commands via Windows Messages. While SageTV itself can also do this with its -event parameter, SendMessage has a few advantages: 1. The SendMessage exe file is smaller than the SageTV exe file, so it will load and run faster. 2. Unlike the -event parameter, the SendMessage utility is capable of sending multiple commands each time the program is run, making it easier to ‘batch process’ a series of commands. 3. SendMessage can be used to send messages to any Windows program. Usage If SendMessage is run without any parameters, it will display a dialog with a brief outline of its usage instructions. The utility uses the following command line format: SendMessage WindowClass WindowName MsgID wParam lParam <repeat param list> … The above-referenced Sending Commands via Windows Messages section lists the values to be used for each of those parameters in order to send command event numbers to SageTV or SageTVClient. To send multiple messages, simply send another series of those five parameters after the first five. In addition to those parameters, default values for each parameter can be defined when you wish to send multiple messages: once a default value is set, that value can be skipped in the list of parameters for additional messages to be sent. To define default values, use the following options. Note that the values are not case sensitive (-c is the same as –C): -C WindowClass – Define the window class name to receive multiple messages. -N WindowName – Define the name of the window to receive multiple messages. SageTV V7.0 User’s Guide Appendix J: Using the SendMessage Utility Page 282 Copyright 2010 SageTV, LLC All rights reserved For additional support, go to www.sagetv.com/support.htmlor email us at support@sagetv.com -M MsgID – The Windows message number to be sent; decimal value. -W wParam – The message’s wParam value to be sent; decimal value. -L lParam – The message’s lParam value to be sent; decimal value. -D DelayTime – Time, in milliseconds, to delay between each message sent. This parameter is not usually needed, but was added in case such a delay was ever desired. Any parameters that contain spaces, perhaps the WindowClass or WindowName of some application, can be enclosed in quotes, such as: -C “Window Class”. Example Use To show how the parameters might be put into use to control SageTV, let’s take a look at a common desire: to have SageTV go directly to a menu that currently has no direct-access command. The Plugin Manager’s All Available Plugins menu is one such location. The following series of commands will go to that location from anywhere within SageTV: Home –Event number 28; go to the Main Menu. Page Down – Event number 56; Page Down to make sure the bottom menu item is highlighted. Up –Event number 4; arrow Up to the Setup menu item. Right –Event number 3; arrow into the Setup submenu. Page Up –Event number 55; Page Up to make sure the top submenu item is highlighted. Down,Down –Event number 5; arrow Down to the SageTV Plugins menu item. Right –Event number 3; arrow into the SageTV Plugins submenu. Page Up –Event number 55; Page Up to make sure the top submenu item is highlighted. Select – Event number 20; Select the All Available Plugins submenu item to go to that menu. Putting all the above options together, SendMessage can be used as follows to issue this series of commands for SageTV: SendMessage.exe -C SageApp -N SageWin -m 1258 -W 0 42 28 56 4 3 55 5 5 3 55 20 SageTV V7.0 User’s Guide Appendix J: Using the SendMessage Utility Page 283 Copyright 2010 SageTV, LLC All rights reserved For additional support, go to www.sagetv.com/support.htmlor email us at support@sagetv.com In this example, SageApp is the name of the window class receiving the message; SageWin is the name of the window to receive the message; 1258 is the message ID number; 0 is the wParam value; and “42 28 56 4 3 55 5 5 3 55 20” is the series of command event numbers to send to SageTV. Note: To control SageTVClient, use SageClientApp instead of SageApp.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. |
Check out page 217 of the manual for details but nyplayer's post summarizes it from a different manual page. User manual: http://download.sage.tv/SageTV_Manual.pdf
Thx, but you didn't need to reprint the entire appendix. I already went online and read it. It doesn't make anything any clearer.
I already tried creating a batch file based on that info. It didn't work and I have no idea what I did wrong. |
How about posting your batch file so we can take a look? The example shows -W but the section I posted says to use lParam. Maybe try -L instead of -W
According to the List Of All SageTV Commands, sending Event # 63 jumps to "LiveTV". See Appendix D, and then specifically page 224 in the user manual.
Modems and switches | rfeyer | Hardware Support | 6 | 04-17-2017 02:48 PM |
I have a question about switches. | rnadeau | Hardware Support | 29 | 07-10-2012 08:57 PM |
Change JVM switches | CadErik | General Discussion | 0 | 12-30-2008 01:40 AM |
Two ATX Power Switches? | EdwardATeller | Hardware Support | 4 | 04-13-2008 02:31 PM |
Routers, switches, et. al. | ToonGal | Hardware Support | 23 | 03-13-2004 11:11 PM |
