Old 08-13-2020, 05:32 AM
Mugsy Mugsy is offline
Question Sage refuses to launch. Wrong Java?
I'm not sure what I did or when, but suddenly Sage refuses to run, giving me the following error on launch instead:
Could not get information on current JVM.
Please install Java Runtime Environment 1.7 or higher.
I've already downloaded and installed (and rebooted) the latest version of Java twice.
I don't wish to reinstall Sage just to fix this. Anyone know what's going on? TIA
Old 08-13-2020, 07:19 AM
sic0048 sic0048 is offline
Anytime you update Java, it seems to break SageTV. This is why we generally don't allow Java updates unless it is critical (so be sure the auto update feature is turned off).
The fix isn't that hard. Simply uninstall SageTV using the Windows uninstaller (don't worry, it doesn't delete your important setup files), reboot and run the SageTV installer for the correct version.
This will fix the issue and all of your settings, favorites, recordings, history, etc are retained.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 08-13-2020, 07:54 AM
Thx for the reply.
Just my luck, I have No "uninstall" entry in my list of installed Windows apps (I had to restore an earlier install of Windows to fix other issues.)
I'll use "Revo Uninstaller", but how can I protect/backup my settings (including EPG123) so I don't lose them?
Thx.
Old 08-13-2020, 08:01 AM
Ok, since the Install entry is missing, I simply ran the SageTV installer and reinstalled it to the same location.
Everything works now and nothing was lost. Thx.
Launch Sage at boot ecojam SageTV Linux 13 03-01-2010 10:48 PM
Launch another program via sage menu ANT SageTV Studio 2 06-30-2007 06:31 AM
Launch Sage Client from SageTV? And another question. silkshadow SageTV Software 6 09-12-2005 01:16 PM
Sage now crashing on launch (XP-SP2 issue?) Bear SageTV Software 5 07-02-2005 07:21 AM
Sage won;t launch, java error, help! robisc SageTV Software 4 09-07-2004 04:48 PM
